stud girdle or 4 bolt mains
powerstrokeace
stud girdle or 4 bolt mains Empty stud girdle or 4 bolt mains
Post  powerstrokeace June 6th 2013, 10:58 am
guy's while my block is torn down i pondering which way to go. as i'm just wanting to build a back up "a" head short block for my stuff after what happened this month.
so i have a dove block .080 over with bronze bushing and roller cam bearing. shouls i install 4 bolt maind and have it aligned honed or install a stud girdle
and who's stuff do you recommend?
Ace
powerstrokeace
powerstrokeace
stud girdle or 4 bolt mains Empty Re: stud girdle or 4 bolt mains
Post  dfree383 June 6th 2013, 12:32 pm
Program makes the nicest caps IMO but they aren't cheap.
Don't waste the time on any of the cheap girdles, only ones worth a crap are the ones that require you to machine the tops of the caps flat and have full contact with the girdle.
Post  IDT-572 June 6th 2013, 12:45 pm
dfree383 wrote:Program makes the nicest caps IMO but they aren't cheap.
X2..............
Post  powerstrokeace June 6th 2013, 12:51 pm
ANY LINK TO PROGRAM?
ACE
powerstrokeace
powerstrokeace
Post  IDT-572 June 6th 2013, 12:59 pm
Here you go...........
http://www.pro-gram.com/
Post  powerstrokeace June 6th 2013, 1:21 pm
GREAT! CALLED THEM AND LEFT A MESSAGE. HOPE THEY CALL BACK.
ACE
powerstrokeace
powerstrokeace
Post  IDT-572 June 6th 2013, 2:34 pm
You can probably buy them cheaper through one of there distributors. Just ask them if they have one near you.
Post  powerstrokeace June 6th 2013, 6:29 pm
WOW!!!!!!!!!!!!!!!
JUST TALKED TO A SHOP HERE IN TOWN AND THEY WANT $700 IN LABOR JUST TO DO THE 4 BOLT MAIN CONVERSION NOT COUNTING THE PARTS. AND THATS ONLY JOURNALS 2,3,4
ACE
SORRY FOR THE CAP'S THE COMPUTERS AT WORK ARE FIXED LIKE THIS
powerstrokeace
powerstrokeace
Post  DJStang June 6th 2013, 6:39 pm
Wow..that's nuts for just the caps. I had some quotes a few years ago for $350-$400 to machine the blocka and align bore the caps. Can't see why it would be double that now.
DJStang
Post  the Coug June 6th 2013, 6:39 pm
Ace just get you some 3/4 or 1" strap and have the caps cut flat and make a strap that goes across the main it will keep it from Bowing in the middle....
Post  466cj June 7th 2013, 1:21 am
the Coug wrote:Ace just get you some 3/4 or 1" strap and have the caps cut flat and make a strap that goes across the main it will keep it from Bowing in the middle....
X2 old school works! Add some good studs and a quick line hone be in business.
466cj
Post  dfree383 June 7th 2013, 1:24 am
https://www.429-460.com/t3597-cap-straps-installed?highlight=Cap+Straps#38811
Not as good as 4 bolt caps, but a whole lot better than a cheap girdle.
Post  IDT-572 June 7th 2013, 10:55 pm
X2 Check with a dial bore gauge and sometimes line honing is not needed. (if your lucky)
Post  466cj June 7th 2013, 11:48 pm
Yeah we were always too lazy to do that. Laughing Just about everything would get a quick hone just to see where everything was at. Gauge does not tell all and yes if the crank spins free likely in line, but a pass with the hone tells all.
466cj
