A-Headed 528" pump gas: 843 hp 700 lbs ft
A-Headed 528" pump gas: 843 hp 700 lbs ft  Empty A-Headed 528" pump gas: 843 hp 700 lbs ft
Post  G-Code June 15th 2013, 2:40 pm
Started playing with this last year had local friend, engine builder, James Bostick build this for me.
Dove A block .060 over ( aftermarket 4 bolt kit, block from Paul Kane)
521" FRPP kit 4.30" stoke, Eagle rods,replaced SRP pistons with JE's to work with A-460 heads 82cc chamber
'93 A-460 heads 2.3 intake heads flow 420 cfm at .750
Schneider solid roller: @ .050" 276-284 ( adv. 306-312) lobe lift .430int - .435ex, lobe sep 112
gross lift .744int .752 ex
I bought the FRPP 521" rotating kit from Lem Evans, along with the Danny Bee from Lem. ( thanks)
we ended up at 11.25:1 compression to run 91 octane
A-Headed 528" pump gas: 843 hp 700 lbs ft  521Ahead2_zps276fe496
A-Headed 528" pump gas: 843 hp 700 lbs ft  521crank_zps8d87f458
A-Headed 528" pump gas: 843 hp 700 lbs ft  521Ford_zpsd7233848
A-Headed 528" pump gas: 843 hp 700 lbs ft  528wheads_zpsb9168d81
A-Headed 528" pump gas: 843 hp 700 lbs ft  528intake_zpsd8dca65a
A-Headed 528" pump gas: 843 hp 700 lbs ft  528dyno_zpseaadfb07
Final results: 1,200 Dominator ... a day at Westec ( Thanks Steve)
A-Headed 528" pump gas: 843 hp 700 lbs ft  239ea951-0e9e-41ee-b5d4-0c75ee44e0bd_zpsc6b2656a
we started with 28* for the 91 octane. Steve ran it to 6,000 after looking at the numbers we bumped it to 30* ran it 6,000 reviewed it then bumped it to 32* and made another 6,000 rpm pass. We decided to leave it at 32* never made another timing bump.
ran it with a 950 ultra HP to see what it would do, lost 40hp: look what happened to the manifold vac ...
A-Headed 528" pump gas: 843 hp 700 lbs ft  527c74ae-cad1-44c0-b9bb-d28bb0636e78_zps3983e044
comparison chart: of two carbs
A-Headed 528" pump gas: 843 hp 700 lbs ft  45787bf7-28d0-4415-9800-9b20d6c55c69_zps5efb490a
Before we put the 950 Ultra HP on we ran a back to back run Valvoline VR-1 20/50 vs Mobil 1 10/30 synthetic. Picked up 10 lbs ft at peak trq ( 5,100) and 10hp at peak power 6,900.
it made 833 with 20/50 and 843 with the Mobil 1. Change to lighter oil cost 6-7 psi across the rpm range.
video results: click on to watch
A-Headed 528" pump gas: 843 hp 700 lbs ft  Th_Dyno528_zps2532bb88
In our future: we are going back in a couple of months or so
A-Headed 528" pump gas: 843 hp 700 lbs ft  528tr_zps086251a9
it just might get interesting ....
A-Headed 528" pump gas: 843 hp 700 lbs ft  E6b34754-042d-45ec-ab90-4a38cf26cbe5_zps637be530
We will run a set of 1,050's on it to just to see what will happen.
Jon
A-Headed 528" pump gas: 843 hp 700 lbs ft  Empty Re: A-Headed 528" pump gas: 843 hp 700 lbs ft
Post  Lem Evans June 15th 2013, 7:20 pm
Nice job! That's gonna be one fun boat engine.
Post  Lem Evans June 15th 2013, 7:39 pm
Being that this is a bad fast lake/river jetboat rather than a all out drag boat I'd think a 110* LSA would be 'meaner' with the size impeller I would run in that application.
Post  dfree383 June 15th 2013, 10:47 pm
Good job G!
Post  G-Code June 16th 2013, 12:43 am
thanks.. I'm happy with it, I am wondering what the new "tall"  TFS single would be worth on it ?
Not sure the video link worked it stopped working on my computer, is it still working ?
I'll repost it:
Post  dfree383 June 16th 2013, 3:46 am
My 528 had a little better heads 465 cfm @ 800, slightly more cam and the new TFS intake and made 905hp @ 7100 rpm a few years back.
Post  G-Code June 16th 2013, 11:44 am
stout  !!!!
how much compression? pump gas ?
Post  dfree383 June 16th 2013, 11:48 am
It was about 12:1 ran on race fuel, never tried it on pump gas, probably would have ran fine seeing that the  cam was pretty big.
Post  austin460 June 18th 2013, 5:56 pm
Nice be really interested to see what predators run like. I'm running a single predator at the moment but have another if I decide to go that way or might just get a 1050 dominator. having said that my motor nowhere near as strong as yours. Interesting on the oil as well, do you not worry about the lack of zddp in the mobil or do you use an additive?
austin460
austin460
Post  G-Code June 19th 2013, 12:31 am
How much power is your Predator supporting ? How does it run?
The oil will get some Lucas additive or I might switch to the Mobil 1 20/50 V-Twinn oil for Harley's it still has lots of the "good stuff" in it.
Jon
Post  austin460 June 19th 2013, 1:33 am
My engine only putting out around the 550 mark, but would of thought it should support more. Just that
motors like to eat. Lol
austin460
austin460
Post  G-Code June 19th 2013, 6:08 pm
austin460 wrote:Nice be really interested to see what predators run like. I'm running a single predator at the moment but have another if I decide to go that way or might just get a 1050 dominator. having said that my motor nowhere near as strong as yours. Interesting on the oil as well, do you not worry about the lack of zddp in the mobil or do you use an additive?
For now I'll just drop some of the Lucas oil treatment in it:
A-Headed 528" pump gas: 843 hp 700 lbs ft  Lucas_zps89f2a796
In the future I'll run one of these types at oil change time.  They are proud of it I'll tell you that.
A-Headed 528" pump gas: 843 hp 700 lbs ft  Mobil1040_zps8c02df95
Post  austin460 June 20th 2013, 4:12 am
Should have said I have run the predator on the street for about 2 years on a dual plane with 2" spacer but am going to a Victor this year, I have had no problems at all. Don't know how much you know about them, but I have found the following it is critical that the thin rubber on top of the top flaps lays nice and flat,and when tuning an 1/8 of a turn on the mixture screw is alot and always take the backlash out Another thing I have done is made a simple baffle for the float bowl as they can suffer with fuel slosh on cornering dependant on which way they are mounted.
Thinking about your application running 2 it might be worth swapping out the spray bars for ones with smaller holes cos they do have a tendency to run rather rich.
I haven't tried it but there is an email address on their website under the contact tab, they may be able to help.
I think I said I may try a 1050 dominator at some point if I can find one for the right price or if a tunnel ram comes up I do have a second predator.
austin460
austin460
Post  LovesDemCubes August 27th 2013, 10:46 am
G-Code wrote:Started playing with this last year had local friend, engine builder, James Bostick build this for me.
Jon
Looks like fun and a great combo. Wonder how it would run with E-85?
Is that too much cam for a street car(i.e. A/C, Power Brakes/Steering, etc.)
LovesDemCubes
Post  maverick August 28th 2013, 1:48 pm
The Mobil 1 15w50 has a ton more zinc than the others. They also have a 0w30 and a 0w50 racing oil that's loaded...not sold in stores, find it online in cases of 6 and in drums.
Post  J.Toney July 18th 2015, 5:32 pm
Ever go back to see what the TR or newer TFS intake will do??
I'm piecing together a very similar build, little more lift, 2 more points of comp, and newer TFS head, Blake doing a light amount of work on them. I  like what I see for the $ I have involved so far, and excited for results. Great build. 1800rpm between peaks is nice!
J.Toney
J.Toney
Post  G-Code August 3rd 2016, 11:40 pm
Post  J.Toney August 3rd 2016, 11:42 pm
Saw that. Too bad I've got 95% of needed parts to assemble mine.
J.Toney
J.Toney
