valve height?
valve height? Empty valve height?
Post  capncruncher1965 June 22nd 2013, 3:05 pm
BUYING new valves and not sure which ones I need?
capncruncher1965
capncruncher1965
valve height? Empty Re: valve height?
Post  Paul Kane June 22nd 2013, 3:15 pm
A factory assembled D0VE head with OEM valve train normally has a 1.82" installed valve spring height. The OEM D0VE intake and exhaust valves have 0.350" & 0.400" tip lengths (+/).
You asked about upgrading the D0VE heads to accomodate a roller cam that has about 0.650" lift at the valve, and such a set up would typically use a 1.900" installed valve spring height. The common fix under these circumstances is to simply use SCJ valves which are the same overall length as the OEM D0VE valves but have 0.250" tip lengths.
Paul
P.S.: There will be other necesssary machining and setup of the heads in order to accomodate the overall roller cam valve train setup.
valve height? Empty THANKS PAUL
Post  capncruncher1965 June 22nd 2013, 3:56 pm
SO WHAT YOU ARE SAYING IS get the stock scj valves and they should be the right height?
capncruncher1965
capncruncher1965
Post  rmcomprandy June 22nd 2013, 5:47 pm
capncruncher1965 wrote:SO WHAT YOU ARE SAYING IS get the stock scj valves and they should be the right height?
I think he is saying to get the Ford Racing SCJ valves, (2.200"), with the .250" tip lengths.
The 2.250" diameter SCJ valves are no longer available from FRPP.  Lem Evans had a bunch of 'em and probably still has some.
OR, get others with those same dimensions.
valve height? Empty THANKS GUYS
Post  capncruncher1965 June 23rd 2013, 12:27 am
will GET UP WITH LEM thanks again guys
capncruncher1965
capncruncher1965
