1050 Dommy Vs. 1050 4150 series carb?
Tore
1050 Dommy Vs. 1050 4150 series carb? Empty 1050 Dommy Vs. 1050 4150 series carb?
Post  Tore June 28th 2013, 8:01 am
I have a hard time understanding how a 1050 4150 series carb can flow the same as a 1050 dommy? Looking at them it doesn't look possible.
Can you take and dyno an engine with a 1050 dommy and then bolt on a 1050 4150 series carb and get the same results?
Maybe somebody can explain this to me.  Rolling Eyes   Tore
Tore
Tore
1050 Dommy Vs. 1050 4150 series carb? Empty Re: 1050 Dommy Vs. 1050 4150 series carb?
Post  richter69 June 28th 2013, 11:31 am
booster size and restriction.
The spacing of the bores plays a role also.
Post  Lem Evans June 28th 2013, 11:39 am
A proper 4500 carb will make more power.
Post  bbf-falcon June 28th 2013, 12:38 pm
Tore wrote:I have a hard time understanding how a 1050 4150 series carb can flow the same as a 1050 dommy? Looking at them it doesn't look possible.
I have often thought about it too Tore. I always thought it had alot to do w/the amount of air that could flow through,but sure don't look like a 1050 4150 could flow nearly as muck as Dommy.scratch
Post  hookin78 June 28th 2013, 12:57 pm
It just reinforces the fact that CFM of air flow is important ..... BUT, it isnt the entire story.....Cool
hookin78
Post  Tore June 29th 2013, 9:29 am
To me it just doesn't look possible.
Tore
Tore
Tore
Post  dfree383 June 29th 2013, 9:47 am
Lem Evans wrote:A proper 4500 carb will make more power.
X2 Booster and Venturi configuration is alot better in the dominator.
Post  rmcomprandy June 29th 2013, 10:48 am
Not figuring ANY part throttle levels or transient responses and just Wide Open Throttle positioning:
More PEAK torque ... yes.
More PEAK horsepower ... most of the time.
More street/strip power UNDER peak torque ... almost never.
A better average in all power over the entire USABLE range of RPM ...sometimes.
USABLE ... is the main thing here as different scenarios and the way the different engines and vehicles  are used will change the definition of what USABLE means.
It is NOT so "cut and dried".
Post  Lem Evans June 29th 2013, 11:18 am
Who the hell wants to operate under peak tq. , that's no fun Laughing
Post  Lem Evans June 29th 2013, 11:41 am
If a guy was looking for a good performing carb with great part throttle the QFT 950 would be the way to go i.m.o.
Post  maverick June 29th 2013, 11:44 am
On a dragstrip, in a car with a transbrake, I tend to think of my Dominator as a sort of "air/fuel toggle switch"...it's pretty much either ON or OFF, so to speak. Obviously, street use puts much more fussy demands on a carb, so peak power numbers may have to be sacrificed a bit in the interest of road manners.
I do agree that the Dominator is the better power maker when the "toggle switch" mode of operation is in play.
