1050 dommy and motor is lean?
I put my car on the rollers this past saturday. My motor is a .030 460 with trw2443 pistons c9 heads with port work and cj valves. The rods are stock crank is stock. The cam is a .292(i think) .631 solid roller with a vic intake and 1050 dommy. The car made 442 to the tire with a c6 tranny and 9in rear. My question is since its lean would a 850dp be a better carb. My thoughts are maybe my motor is not pulling enough air through? The a/f was lean the whole pull. I had a head gasket start leaking to. Pulled the heads off last night and 3 maybe 4 cly was leaking compression. What should I torque my head bolts to with moly lube? Im using stock head bolts. Thanks
Bigblockfox- Posts : 47
Re: 1050 dommy and motor is lean?
What is the size of jets and are the pv's blocked?
The dommy is stock. I have never opened it up.
bring it over and let me have a look see.................
130-140# final torque, oil on the threads and face of the bolt.
richter69 wrote:bring it over and let me have a look see.................
Bring the car? or carb? We are going to put the heads back on thursday. I sent you a pm on streetcars.
» 1050 Dommy Vs. 1050 4150 series carb?
» 460 engine failure 800 miles street use
» 1050 Quick Fuel Dommy
» looking for a good used 1050 dommy core
» Good jet & air bleed starting point for 8896-3 1050 dommy
