oil psi issues
+14
Dave C.
soupbean
LivermoreDave
KY JELLY
Wheelie58
18 posters
Page 3 of 3 Previous  1, 2, 3
oil psi issues - Page 3 Empty Re: oil psi issues
Post  LivermoreDave July 29th 2013, 12:48 am
Here's a different approach.
oil psi issues - Page 3 OP5_zps7c493ea5
oil psi issues - Page 3 OP9_zps405955cf
oil psi issues - Page 3 OP15_zps620e4131
oil psi issues - Page 3 OP13_zpsefb1b24d
oil psi issues - Page 3 OP17_zpsc35476ab
LivermoreDave
Post  bbf-falcon July 29th 2013, 9:14 am
Lem Evans wrote:oil psi issues - Page 3 Stevenspan
This is the pan that is on QTR Warrior's engine. Another plus of the taller front wall is .....while it does reduce the total area of the pan, the capacity of the sump goes up.
Lem,what type of a die grinder are you using there? And you need to be wearing safety glasses,you gonna put your eye out.Razz
Post  LivermoreDave July 29th 2013, 11:54 am
Has to be battery operated! I don't see any scuba gear to provide air.
Dave.
LivermoreDave
Post  richter69 July 29th 2013, 2:50 pm
external pump for the win, smash your pan and keep on racing..............Very Happy
my sump area is reduced in size now lol
Post  Lem Evans July 29th 2013, 8:26 pm
Here is another approach......Fabio pan. I suspect he puts new bearings in it every week.
oil psi issues - Page 3 Wet-externanpan002Small
Post  LivermoreDave July 29th 2013, 10:35 pm
Lem Evans wrote:Here is another approach......Fabio pan. I suspect he puts new bearings in it every week.
Except for the dent on the side, looks pretty good from the outside! What's inside?
Dave.
LivermoreDave
Post  c.evans July 30th 2013, 12:07 am
I've had my hands on that pan Dave, and if my memory is correct, right about there on the inside is where a trap door baffle is welded in.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  richter69 July 30th 2013, 8:36 am
Its about an inch shorter now in the rear than in that pic.......
Post  Lem Evans July 30th 2013, 10:41 am
Dave.
Chewed up bearings.
Post  richter69 July 30th 2013, 10:44 am
no chewed up bearings here..................that pan wont fit a 6.7......Razz
Post  Lem Evans July 30th 2013, 7:42 pm
richter69 wrote:Its about an inch shorter now in the rear than in that pic.......
Better under body aerodynamics....
Post  cool40 July 30th 2013, 11:32 pm
He can use a small diaper now....Razz
Post  LivermoreDave July 30th 2013, 11:49 pm
Dave.
Chewed up bearings.
Probably from a lack of oil pressure!
Dave.
LivermoreDave
Post  cool40 August 5th 2013, 10:56 pm
another pan i'll try sometime.... oil psi issues - Page 3 Drysump001
