1st Pas this year with to kits
512Fairlane
whitefield
The kid let it get a little high on rpm on the 1-2 shift and the 8800 rpm window switch shut the nitrous shut off for .07 sec . But I thing this is a cool view!! 7.70 @ 182 mph
Frank Merkl- Posts : 1524
Re: 1st Pas this year with to kits
Very Bad Ride you have there Mr. Merkl!
whitefield- Posts : 2244
Man that's clippin!!! Hell of a ride you've got Frank:twisted:
Mike R- Posts : 1381
That's awesome.
512Fairlane- Posts : 694
it'll run a bunch faster after the next couple of passes as that was with only 6 degrees total timing - the plugs were perfect with just a slight fuel ring at the base of the of the porcelain but the egts on that pass hit 1965 degrees F !!!! the next pass we upped the timing 1 degree to 7 and the egts dropped 100'F , my new silver ceramic coated headers have a frosted look from about 2" from the head to about the 1 ft mark !!! We cut 10 sets of plugs tuneing the kits on the weekend!!
PS watch it in slow mo and watch the tire tracks for shake !!!
Very cool!
61coon- Posts : 1824
Sounds damn strong Frank.
What kind of 60/330/660 numbers did it have?
DILLIGASDAVE- Posts : 2262
Glad to see you are back out again.
Looking forward to more of your results.
I'll be bringing my car down to the Hat later this year.
Ranch71460- Posts : 284
» Pro comp heads in the final last year semi's this year.
» Two Kits on BBF
» Kits
» NOS Purge Kits....
» 445 fe stroker kits
» Two Kits on BBF
» Kits
