Two Kits on BBF
Two Kits on BBF
anybody running two kits?
how much 1st and 2nd
delay or all in?
small tire or big tire
delay or all in?
studly- Posts : 512
Re: Two Kits on BBF
no good data yet ...
it has ran a 5.61 @ 127 on the first kit with a 1.32 60' and it has ran a 5.62 @ 130 with a 1.34 60' with both kits on ...the 2nd was turned on at 2 seconds into the run 22* on the first kit and 18* w/ the 2nd kit ....
we are working on the rear tubs right now and we are going to a bigger tire .....
first kit tune ---- 73/63 @ 5.5 timing at 22*
2nd kit tune --- 20/24 @ 5.5 timing at 18* ( note 22 jets on the end runners ) .........
the track was great ...but i had a very hard time getting down it......
Re: Two Kits on BBF
thats good info i am still working with mine i am going out this friday still with the first kit but 300hp nos and going to try to leave with all the timing in the car hopefully i can run some numbers fastest so far 5.66. i think i can run 5.50s with the tune up if i can leave with it all in my best 60 so far is 1.34 i need to be in the 1.20s to run the ET i want to run.
studly- Posts : 512
Re: Two Kits on BBF
i believe i can run in the 50's with the first kit .... just got to get to the track
Re: Two Kits on BBF
I have two systems now with both being foggers. With my last motor (514) I had two Speedtech systems with one a fogger and one a plate. I usually used the fogger first with 200-225 shot and then grabbed 100-150 more with the plate out .6 in the run. Oh yea I run 33x17’s @ 2400 lbs. I have data and have tried several different combos but our set up’s are completely different. Best run was a 4.94 @142mph.
valleydawg- Posts : 427
Re: Two Kits on BBF
Thats a nice car you have!!valleydawg wrote:I have two systems now with both being foggers. With my last motor (514) I had two Speedtech systems with one a fogger and one a plate. I usually used the fogger first with 200-225 shot and then grabbed 100-150 more with the plate out .6 in the run. Oh yea I run 33x17’s @ 2400 lbs. I have data and have tried several different combos but our set up’s are completely different. Best run was a 4.94 @142mph.
James Hahn- Posts : 23
