HAVE A C6 LONG SHAFT,2 MOUNTS ON EACH SIDE OF CASING
came out of 76/77 lincoln, putting 460 and this trans in 79 Ranchero. will not fit this crossmember(was an fmx/351). are there other model that I can get crossmember from or do other casings not have the 2 mount set up?
RANCHEROMAC- Posts : 13
Re: HAVE A C6 LONG SHAFT,2 MOUNTS ON EACH SIDE OF CASING
The standard c6 only has 1 mount right in the center of the tail shaft housing.
Some of the big car C-6 transmissions had an "odd ball" rear mount. The mounting pads on the tail housing are on about a 45 degree angle, I don't know what the rubber mount looks like, but I fabricated an adapter to bolt to the "standard type" in my daughters big block Fox.
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
I have done an adaptor as well . The mount looks like http://www.bakersauto.com/MOUNT-REAR-TRANSMISSION-66-67-68-69/productinfo/TM66/
I have also altered the crossmember to suit this
Gregaust- Posts : 625
Same here, I got my tranny used from another racer and he modded the Lincoln trans mount to suit a Fox x-member. Fits fine.
BigRigTech- Posts : 763
» Side X Side Dirt Drags, Ottawa County Fair July 30th
» deck side V intake side
» Went to the dark side...................
» Morning funny....
» E85 on nitrous side only
» Morning funny....
