Anyone know where the oil level in the pan should be at ?
Does anyone know how far down from the oil pan rail on the block that the ( full ) oil level in the pan should be on a production (83-97) 460 ?
Does the crank sit in the oil or is the oil level right below the throws?
83-88T-Bird Guy- Posts : 1003
Re: Anyone know where the oil level in the pan should be at ?
Below the throws, as low as possible without running the pan dry.
IS IT A REAR SUMP, IF SO POUR IN 6quarts of water,and you will see
BOSS 429- Posts : 2372
» Advice for Oil level 460 - need to mark dip stick
» moroso oil pan level?
» 460 bracket engine in my 67 comet
» Holley float level clear sight plugs
» Entry Level, Self-Tuning EFI Showdown
