Advice for Oil level 460 - need to mark dip stick
norm
bigblockfordfxstb
Advice for Oil level 460 - need to mark dip stick Empty Advice for Oil level 460 - need to mark dip stick
Post  bigblockfordfxstb September 16th 2018, 6:17 pm
ADVICE : I need to mark my dipstick for correct oil level on aftermarket high capacity sump and dont know if dip stick is original.
So what the oil height level should be at, from the block to oil pickup is around 8". should the level be to below the crank, say just below windage tray level.its around 4".?
bigblockfordfxstb
bigblockfordfxstb
Advice for Oil level 460 - need to mark dip stick Empty Re: Advice for Oil level 460 - need to mark dip stick
Post  norm September 16th 2018, 7:05 pm
I'd change the oil and refill with whatever amount you use, check where the oil is on the stick and mark it there.
norm
norm
Post  bigblockfordfxstb September 16th 2018, 7:11 pm
Hi Norm, that is the problem I dont know how much oil to use. The motor is out and i have access to bottom end and dipstick now so if i know what level it should be then i can measure and mark the dip stick so when its back together its right.
bigblockfordfxstb
bigblockfordfxstb
Post  norm September 16th 2018, 7:23 pm
I don't know any other way to do it. Someone would need the exact same components you have, just saying the sump depth doesn't describe the capacity.
If you list exactly what components you have, pan,dipstick etc. you might get lucky and someone could help.
norm
norm
Post  bigblockfordfxstb September 16th 2018, 7:50 pm
Is it not a basic principle of where oil level should be. Like below the crank weight 1/2 inch etc....the dip stick i think was cut orignally because different pan and the pan is for an australian car so not sure how many people will have the same setup.
bigblockfordfxstb
bigblockfordfxstb
Post  BOSS 429 September 16th 2018, 9:21 pm
post a pic of the pan
Post  bigblockfordfxstb September 16th 2018, 9:37 pm
Thought I did !!!! Ok will try again from mobile.....
bigblockfordfxstb
bigblockfordfxstb
Post  bigblockfordfxstb September 16th 2018, 9:38 pm
Advice for Oil level 460 - need to mark dip stick Smarts11
Advice for Oil level 460 - need to mark dip stick 20180910
bigblockfordfxstb
bigblockfordfxstb
Post  bigblockfordfxstb September 16th 2018, 9:39 pm
The old didnt insert link trick.
bigblockfordfxstb
bigblockfordfxstb
Post  BBFTorino September 16th 2018, 11:09 pm
Front sump pan that appears to be about 8.5" inches deep. I would make sure the engine is level, bolt the pan on, and add 5 quarts, pull the dipstick, and mark it.....then add 3 more quarts and mark it.
Or you could mark it in 1 quart increments up to 8 quarts, then measure how close the oil level is to the crank.
You dont want the crank dipping into the oil. Of course, while its running, the oil level is somewhat lower because its being pumped throughout the system.
Post  BOSS 429 September 16th 2018, 11:49 pm
bigblockfordfxstb wrote:ADVICE : I need to mark my dipstick for correct oil level on aftermarket high capacity sump and dont know if dip stick is original.
set the pan up so it lays back about 2 deg's with an angle finder, then fill with water till it just covers the baffle. Then drain and measure the water, add 1 q for filter.
pan looks small.
Post  bigblockfordfxstb September 17th 2018, 12:04 am
Ok thanks all
bigblockfordfxstb
bigblockfordfxstb
Post  Gregaust September 17th 2018, 5:13 am
What pan are you using? My ASR Pan is marked 8 litres . ASR pan which is same as High Energy also.
8 litres equates to approx 100mm deep which puts oil level just below the windage tray
I do have some pics just need to figure posting here
Gregaust
Post  bigblockfordfxstb September 17th 2018, 8:26 am
Hi Gregaust,
Yes its a high energy unit, long old now... ok Ill give that a trail run with like water as still have time before its going back together !!
bigblockfordfxstb
bigblockfordfxstb
Post  rmcomprandy September 17th 2018, 9:28 am
Different oil pan designs require different oil levels withing the pan while running. I would find out what is recommended for THAT pan and mark accordingly.
Post  bigblockfordfxstb September 17th 2018, 10:31 am
Fair point, will see if I can get an answer from them.
bigblockfordfxstb
bigblockfordfxstb
Post  Gregaust September 18th 2018, 4:46 am
I have both High Energy and ASR pans , identical designs . The H.E when i got it had an amount marked on it of 8.5 litres .
The ASR is engraved on the base near the plug with a serial number and 8 litres
I used some solvent from parts washer to mark the amounts
Gregaust
Post  Gregaust September 18th 2018, 5:04 am
Advice for Oil level 460 - need to mark dip stick DSCN5999_zpszxpv3jj6
Advice for Oil level 460 - need to mark dip stick DSCN6007_zpsl33uo9wo
Advice for Oil level 460 - need to mark dip stick DSCN5992_zpszxc7hbl8
Advice for Oil level 460 - need to mark dip stick DSCN5990_zpsdd3sqbog
Gregaust
Post  bigblockfordfxstb September 18th 2018, 5:06 am
Perfect. I spoke with high energy the said 8.5L ..... big thanks. Only after you mentioned the name did it ring a bell as mine have no marking or stickers anymore.......
bigblockfordfxstb
bigblockfordfxstb
Post  BOSS 429 September 18th 2018, 8:36 am
just wondering if you checked after they told you to see what it held to the baffel in quarts?
Post  bigblockfordfxstb September 18th 2018, 8:55 am
Not yet..... so should be measuring how many L to baffel then what 8.5L
bigblockfordfxstb
bigblockfordfxstb
Post  Gregaust September 19th 2018, 4:36 am
In those pics is my ASR pan. It is identical external shape to High Energy that I also have .  In that pic is the ASR and the amount is 8 litres as shown as per what is engraved on the base. The 8 litres is just under the louvered plate @ 100mm deep
My High Energy had a small sticker on it when I got it said 8.5 litres .  Just dug out my notes , 8.5 litres was 105mm deep.
The extra 1/2 litre was 5 mm higher up the stick, not a big difference either way
Gregaust
