Valve stem seals - D3s
Hey guys, its been a while...
Im working on a buddies D3 heads with double springs and need a set of valve seals.
.495" OD on the top part of the guide, .700-.705" on the ID of the inner spring and 11/32" valve stem.
I cant seem to find what I need online. Any help would be appreciated.
edit:
This is on a 9.2:1, moderately sized hydraulic flat tappet cam, pump gas, 466. Nothing overly fancy or extreme.
edit:
IcallhimGeorge- BBF CONTRIBUTOR
Re: Valve stem seals - D3s
Long time no see there Kris.
schmitty- Posts : 4538
I should be around a little more frequently now. After about 3 years of down time Im finally getting my ducks in a row to rebuild the 521 for George.
IcallhimGeorge wrote:Hey guys, its been a while...
edit:
A PC type seal comes in several brands ... what brand is your preference...?
Randy,
I really dont have a preference.
Mustve missed these.
http://www.jegs.com/i/Comp-Cams/249/506-16/10002/-1?parentProductId=746969
Any reason these wouldnt work?
I told your little sister from the north they weren't anything special. Just get some PC seals of the correct size and go. If you can't find them online, any decent machine shop in your area probably has some seals in stock or can get them quickly enough.
kjett- Posts : 1169
Karl,
He told me. I tried to tell your hermaphrodite son that stock D3 umbrella seals wouldnt work with the inner spring. I didnt think they were anything special but I knew stock wouldnt work. Im thinking 2.3 Ford seals from the parts store wouldve worked but I got these coming.
Thanks guys.
Thanks guys.
» Valve stem seals
» Valve stem seals
» valve stem seals
» Install of VITON Valve Stem Seals
» valve seals
» Valve stem seals
» valve stem seals
» valve seals
