TCI Transmission Cooler
TCI Transmission Cooler Empty TCI Transmission Cooler
Post  MrScharfenberger August 18th 2013, 12:06 pm
[color:2415=#ff3366NO] LONGER FOR SALE
I have a TCI transmission cooler up for sale that I was going to use on my Mustang. It was unboxed and mocked up on the car but has NEVER had any fluid run through it. After I got my vacuum pump & drive mandrel on I discovered that this cooler was only about 1 millimeter away from the drive mandrel so I took it off and got a smaller Flex-a-Lite trans cooler. I now have no need for this one. You can't really see it in the pictures but a few of the fins are mashed over a little bit. It is nothing major and is perfectly usable. You can see it in the first picture on the left side. I just wanted to state that because as it turned out it is hard to tell in the picture. In the second picture you can see the little black padded squares that went between the radiator & the trans cooler. They stayed stuck to the cooler so I didn't pull them off. All pieces are there except for one hose clamp and I may still find that before I sell this. The nylon attaching straps that go through the radiator & trans cooler are also no longer with us. I had it attached but then cut the nylon straps to get it off. You can buy the nylon straps at Autozone. I've seen them in there. Also the male AN fittings that are on it in the picture do not come with it. I need those for my new trans cooler. I just forgot to take them off before I took the picture. It has female AN fittings to attach to. You do not need AN fittings however. The unit comes with the push on hose connectors. Those are brand new in the package as you can see in one of the pictures. It sells for $87.97 brand new at Summit Racing plus their $12.95 to ship. I'll ship this thing to your door in the lower 48 for $60. If you want to pay by Pay-Pal make it $62 shipped to the lower 48 states.
Link to part at Summit Racing:
http://www.summitracing.com/parts/tci-823800
Link to the nylon straps at Summit Racing as a reference:
http://www.summitracing.com/parts/tci-821500
TCI Transmission Cooler TransCooler1
TCI Transmission Cooler TransCooler2
Last edited by MrScharfenberger on August 25th 2013, 8:28 pm; edited 2 times in total
MrScharfenberger
MrScharfenberger
http://www.MrScharfenberger.com
TCI Transmission Cooler Empty Re: TCI Transmission Cooler
Post  Lem Evans August 18th 2013, 12:25 pm
Hi, Chris.
Post  MrScharfenberger August 18th 2013, 1:16 pm
Since this is already on top I'll respond. I'm not trying to break the bump rule if there is one over on this board.
Hi Lem..
Hopefully you got my P.M. on the other board of the first Mustang start up. The thing sounds great! I've been out there this weekend trying to get the front fenders & nose clip painted. I'm ready to drive it! The motor would not have turned out as nice as it is without you! THANKS!!
MrScharfenberger
MrScharfenberger
Post  MrScharfenberger August 25th 2013, 8:26 pm
No longer for sale.
MrScharfenberger
MrScharfenberger
