spacer removal
spacer removal
what is the safest way to remove the spacer that goes on the front of the crankshaft behind the ballancer?
this motor is internally ballanced
Larry Williams- Posts : 884
Re: spacer removal
Larry,I always hone mine a little so it will slide on and off by hand,if that is what u are referring to.
Re: spacer removal
your right rick thats what I am talking about. unfortunately I didn't hone mine.
I am sure I have an aluminum spacer too
Re: spacer removal
A little bit of antiseize doesn't hurt either.
Re: spacer removal
Had to heat mine a little bit to get it off.
Dave C.- Posts : 1268
Re: spacer removal
If its really stuck on there try a muffler clamp and a three jaw puller....
Barry_R- Posts : 35
Re: spacer removal
good idea thank youBarry_R wrote:If its really stuck on there try a muffler clamp and a three jaw puller....
Re: spacer removal
X2 Propane torch will usually do it.Dave C. wrote:Had to heat mine a little bit to get it off.
Re: spacer removal
i got it off with an electric heat gun and a 2 arm puller
» EGR removal?
» msd dist. gear removal
» Exhaust manifold removal
» Timing chain removal
» Thermostat bolt removal
