GEARS, TIRES AND RPMS QUESTION
mustang557
GEARS, TIRES AND RPMS QUESTION Empty GEARS, TIRES AND RPMS QUESTION
Post  mustang557 September 14th 2013, 8:05 am
I HAVE A FOXBODY BACKHALF DRAG CAR WITH 33-15-15 HOOSIER SLICKS. WITH MY OLD MOTOR A 557
AND 4.42 GEAR I WENT OUT THE END AT 154 MPH AND 7200 RPMS. THE NEW MOTOR IS A 598 BUT I
INSTALLED 4.11 GEARS TO TRY AND SOFTEN THE HIT. ALSO I DONT NEEDS TO SPIN THE ENGINE THAT
HIGH. THE CARS WEIGHT IS 2750 WITH ME IN IT. THE OLD MOTOR WAS 825 HP, THE NEW ONE A LITTLE
1000 NA. ANY IDEAS HOW MUCH THE RPMS WILL CHANGE? WOULD STILL LIKE AROUND 6900:D
mustang557
GEARS, TIRES AND RPMS QUESTION Empty Re: GEARS, TIRES AND RPMS QUESTION
Post  dfree383 September 14th 2013, 9:09 am
http://www.wallaceracing.com/Calculators.htm
Post  richter69 September 14th 2013, 10:13 am
same converter?
Post  mustang557 September 14th 2013, 5:36 pm
SAME CONVERTER, STALL IS 5600 RPMS, PG TRANS.
mustang557
Post  richter69 September 14th 2013, 6:22 pm
gonna have to tighten it up, with the changes its gonna blow through the converter most likely.
rpm gonna be higher than before
Post  harpo December 30th 2013, 1:31 pm
ok I am curious... what does "blow thru" the convertor mean, and why would it run higher RPM's. thanks
harpo
Post  bigblok2000ranger December 30th 2013, 2:25 pm
harpo wrote:ok I am curious... what does "blow thru" the convertor mean, and why would it run higher RPM's. thanks
Overpowering the converter, making more power than the converter is able to couple will be similar to slipping clutch.
bigblok2000ranger
bigblok2000ranger
Post  BOSS 429 December 30th 2013, 6:51 pm
mustang557 wrote:I HAVE A FOXBODY BACKHALF DRAG CAR WITH 33-15-15 HOOSIER SLICKS. WITH MY OLD MOTOR A 557
should of left the 4.42 gear in it, and maybe a diff converter
