STANLESS steel marine head gaskets?
WAS WONDERING if the water jackets are same as regular head gaskets?
capncruncher1965- Posts : 131
Re: STANLESS steel marine head gaskets?
Prolly cause the valves to float.
Dave C.- Posts : 1268
NEVER thought of that.
thanks for your reply dave never thought it might float the valves
A poor attempt at being funny. Sorry
LOL you had me thinking
looks like I will have to get felpros
Have you considered cometics?
NEVER tried them
ARE they pretty good
Most of the guys on here seem to like them.
block and heads need finish milling to use the cometics. Great MLS gasket, but sensitive to surface prep.
kim- Posts : 700
THANKS GUYS
SOUNDS LIKE I NEED COMETICS
Two nights ago I lifted a head off of a BBC that had Fel-Pro head gaskets stamped "HIGH PERF / MARINE". Probably not unusual although I thought it was interesting enough to examine. The gasket appeared to have a copper tint unlike the Fel-Pro "Permatorque" series and seemed to be a bit more "tinny". Probably nothing special but interesting to me!
Dave.
Dave.
LivermoreDave- Posts : 972
WERE the gaskets thiner than a regular felpro?
or about the same
I'd think the Felpros would work fine and be alot cheaper.
The cometic stuff is typical used in High compression racing type stuff. Not necessary for a lower compression marine engine.
THANKS GUYS
I GUESS ILL use the felpros THANKS FOR THE INFO
I it would be best to decide on the gasket type before assembly begins. The steel shim gaskets require a bit different block and cylinder head finish than the composite gaskets.capncruncher1965 wrote:I GUESS ILL use the felpros THANKS FOR THE INFO
Dave.
» New TFS MLS head gaskets
» Need head gaskets (Lem?)
» need head gaskets
» head gaskets
» Head gaskets for 429 - which way go on?
» need head gaskets
» head gaskets
