9" Pinion bearing?
9" Pinion bearing?
Anyone have the correct part # for the inner pinion bearing for a 9" rear? Std pinion support and std 28 spline pinion. Changing the gears in my street Fairlane to some more highway friendly gears.
I have the # on the outer bearing. m88048
Re: 9" Pinion bearing?
Here's the whole kit.
http://www.summitracing.com/parts/rmg-8310111
Front Bearing (Timken M88048)
Front Race (Timken M88010)
DeepRoots- Posts : 110
STD. pinion support uses the same beariing in the front and rear . Non std., oem Daytona has the larger rear bearingDavid Cole wrote:Anyone have the correct part # for the inner pinion bearing for a 9" rear? Std pinion support and std 28 spline pinion. Changing the gears in my street Fairlane to some more highway friendly gears.
DanH- Posts : 1081
Thanks to all
Took it apart yesterday and found that they were the same front and rear. In my mind I thought they were different. Old age does that to ya lol.
Anyways, bought 2 new pinion bearings, races and to differential bearings. Already had a new nut, seal, o-ring, etc. Dropping the 3.70's out of the Fairlane and in with some 3.25's for some highway cruising. Will keep the 3.70 center section untouched in case I want to swap back. . Using a std stock center for the 3.25's.
» how do you guys get the bearing off the pinion gear
» Wanted Ford 9" aftermarket case for 3.250 bearing and pinion support/3:91 gears
» KING MAIN BEARING CLEARANCE'S AT PARTING LINE..?
» 9" pinion help
» Pinion Offset
» 9" pinion help
» Pinion Offset
