9" pinion help
bosshoss
64 fairlane
9" pinion help Empty 9" pinion help
Post  64 fairlane February 17th 2011, 11:17 am
Hey guys I was hoping someone here could help me out with a gear change on 9"
Here's the question I purchased a set of 4.11 and plan to install them I had 4.56. I also purchased instalation kit,on the pinion does the bearing get pressed on without any shimms between the bearing and the pinion gear.The pinion for the 4.56 has shimms between bearing and pinion gear. Thanks in advance!
64 fairlane
64 fairlane
9" pinion help Empty Re: 9" pinion help
Post  bosshoss February 17th 2011, 1:24 pm
In most cases there should not be any shims behind the bearing closest to the pinion gear. The exception being if you are using a racing style pinion support that is designed to handle both the 35 and 28 spline pinions. In that case there will be an adapter collar and a washer (roughly .100 thick).
dkp
bosshoss
bosshoss
Post  cool40 February 17th 2011, 3:10 pm
i think the 9" uses shims that go between the support and case,like where the bolts go through them.i know i've used them on stock deals before.
Post  DanH February 17th 2011, 9:25 pm
cool40 wrote:i think the 9" uses shims that go between the support and case,like where the bolts go through them.i know i've used them on stock deals before.
correct , shims between case & support
DanH
Post  quick 52 February 17th 2011, 11:57 pm
you will have 2 set bearing preload shims if u r using a solid spacer in stead of a crush sleeve if u r rcing with it sound like u r u want a solid sleeve with needs to be shim google 9" gear set up there is so good thread with picture its not that hard 2 do but takes alot of time to get it rite most shop will do it 4 $125
dragweek quickest street rod
2009 2010
quick 52
Post  D. Sea February 18th 2011, 1:18 pm
quick 52 wrote:you will have 2 set bearing preload shims if u r using a solid spacer in stead of a crush sleeve if u r rcing with it sound like u r u want a solid sleeve with needs to be shim google 9" gear set up there is so good thread with picture its not that hard 2 do but takes alot of time to get it rite most shop will do it 4 $125
2009 2010
^ This guy texts..... A LOT! lol
D. Sea
D. Sea
