Question on Ford Motorsport Timing Chain
Question on Ford Motorsport Timing Chain Empty Question on Ford Motorsport Timing Chain
Post  77f150 October 6th 2013, 4:26 pm
While being helped out by another board member here on a different question it was suggested to ditch my Pete Jackson gear drive and install a billet timing chain. I've read that the dog bone style is not the greatest and since I have to swap timing cover gaskets this winter it makes sense to fix the problem. Are the parts I'm looking for the Ford Motorsport M-6268-A460 for the timing chain and M-6268-A460 Roller bearing thrust plate? Any special work required for the thrust plate? I run an electric pump so the fuel pump eccentric is not a problem. This is for a '70's ford block with a Comp Cams solid camshaft (34-342-4). Thanks for your help.
77f150
77f150
Question on Ford Motorsport Timing Chain Empty Re: Question on Ford Motorsport Timing Chain
Post  Lem Evans October 6th 2013, 6:15 pm
With the cast cam the B429 set w/cast cam gear is what you need. Use the stock cast retainer plate too.
Post  77f150 October 6th 2013, 7:01 pm
Lem Evans wrote:With the cast cam the B429 set w/cast cam gear is what you need. Use the stock cast retainer plate too.
Thank-you Lem, appreciate your help!
77f150
77f150
