Cometic Head Gaskets
466cj
powerstrokeace
geno
I have never used cometic gaskets before. Pulled the heads and sent them to the machine shop to have them set up for the gaskets. I read that they are to be install dry but some have used copper spray. Do I spray or not. I just don't want to install them twice. Thanks in advance.
geno- Posts : 103
Re: Cometic Head Gaskets
no spray, unless tney are used.
x2..and be sure the block is slick too.
I think the heads and the block need a AR finish some where between 15-25AR smooth as glass.cool40 wrote:x2..and be sure the block is slick too.
Ace
powerstrokeace- Posts : 1496
50 AR or less. Think making sure heads and block are flat is more important.
466cj- Posts : 391
Glass smooth is not required. The best way I know of saying it....a good job not a hatch job.powerstrokeace wrote:I think the heads and the block need a AR finish some where between 15-25AR smooth as glass.cool40 wrote:x2..and be sure the block is slick too.
Ace
The heads are 50AR but the block is still in the car. Would I need to spray the block side of the gasket?
geno- Posts : 103
long as it is flat I'd just run them dry.
466cj- Posts : 391
What surface finish is required to us an MLS head gasket?
A surface finish of 50 RA (roughness average) or finer, is recommended for a proper gasket seal. Anything rougher may conflict with the gasket design.
right off there web site
Ace
Ace
Thank all for the needed advice. I will install the gaskets dry. Thanks again..
geno- Posts : 103
zemetrics.comLem Evans wrote:Anyone know someone who has one of those RA measuring deals? I don't.
maverick- BBF CONTRIBUTOR
I'm not looking to buy one.....the eyeball and thumb nail are working just fine for me:)
doesn't hurt to use some copper coat either.
dfree383 wrote:doesn't hurt to use some copper coat either.
Yep, there are many engine builders that use the copper coat, even with the 'glass' finish that the CBN cutters can give. I don't really see the need for C.C. with a super slick finish but, I will say I'am yet to any downside to using it.
Cooper coat after reused a few times, try to avoid it as is a pain to clean off. Halomar better if you can find it, just have to let it air dry a few minutesdfree383 wrote:doesn't hurt to use some copper coat either.
466cj- Posts : 391
Double post:oops:
Chrysler had a sealant that worked good too. I think it was for their 2.2 liter turbo four.
» cometic gaskets
» cometic mls gaskets
» I got my cometic gaskets now what???
» COMETIC HEAD GASKETS: 4.640 bore .060 thick SOLD
» COPPER HEAD GASKETS
