a head
a head
whats the difference in tfs 5451t8t5-co3 head from summit and the $500 less tfs 5451t805-co3
v-twin- Posts : 52
Re: a head
If thats the difference it'd be $500 well spent.IMO
Re: a head
If you are buying new and your willing to pay for the titanium now versus later you will be way ahead to spend the extra $1050 now. Also I would shop around. Lem, Charlie, and others sell/work on these. I included some others below.
8 titanium valves at $100 dollars and up a piece gets you to $800 so for the extra $200 I dont think you will be able to have the heads redone for the new valves plus if you wanted the 5/16" stem vs the 11/32" stem you will need new guides installed cost $ idk how much but i would say you could easily have $2000 extra putting titanium intake valves in after the thought. unless you could start with a bare cnc head to begin with and even then I doubt you could do it for less.
Part number TFS-5451T8T5-C03 has 5/16" stem titanium intake valves. And 85cc chambers
Part number TFS-5451T804-C04 has 87cc combustion chambers and stainless intake with 11/32" stems
TEA does a version and can add what ever you want
http://www.totalengineairflow.com/products-page/products/cnc-ported-cylinder-heads/ford/bbf-429460/trick-flow-360cc-a460-cylinder-heads/
Proline Racing
http://www.prolineracing.net/index.php?option=com_virtuemart&category_id=85&flypage=flypage.tpl&manufacturer_id=2&page=shop.product_details&product_id=334&Itemid=4&vmcchk=1&Itemid=4
Again this is just an opinion.
Hope this helps
Proline Racing
Hope this helps
460pulling- Posts : 249
A head
thanks. I'm new to the trick flow heads.
v-twin- Posts : 52
Re: a head
460pulling wrote:If you are buying new and your willing to pay for the titanium now versus later you will be way ahead to spend the extra $1050 now. Also I would shop around. Lem, Charlie, and others sell/work on these. I included some others below.
Proline Racing
http://www.prolineracing.net/index.php?option=com_virtuemart&category_id=85&flypage=flypage.tpl&manufacturer_id=2&page=shop.product_details&product_id=334&Itemid=4&vmcchk=1&Itemid=4 thanks learning a lot here
Hope this helps
v-twin- Posts : 52
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» coolant leak between head and block at head bolt location.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» Which Head?- 598 NA
» P51 Head HP gain after head port
