F250 clunking noise ?
capri-sun
I keep on getting this clunking noise on the front left ---usually when you brake --- this dealership cant find the issue --they replace an abs assembly several months ago and they said the noise was fixed ---Not --- any ideas Jonny Boy
Re: F250 clunking noise ?
bruno, 2 or 4 wheel drive,, stock or aftermarket wheels,, gas or desiel. info please
capri-sun- Posts : 346
4 wheel drive , deisel , stock wheels...... and it has 15,000 miles on her its and 2006 f250 6.0
did you gheck ball joints , tie rod ends, wheel bearings, & bushings
dealerships suck, the mech dont get paid for diagnostic time so half of them say f%uck it!
Had a 96 once that had the same issues. No one could find the problem. Ended up being the lower shock bushing was gone. Worth a look.
TravisRice- BBF CONTRIBUTOR
my 95 f350 is making a noise done check all front end parts and can't find it I thinking it might be coming from a shock going to change them out see if it goes away
Check the sway bar links and sway bar bushings on the diff. I just put new sway bar bushings on my 99 F250 4x4 and tightened up the loose lower bolts in the end links. The clunking noises are gone. One other thing I have seen on these trucks - the seat tracks - as stupid as it sounds I have seen them clunk and snap too under braking.
BigRigTech- Posts : 763
Ball joints are high on the list of things to check, especially if they have never been replaced. Also check the front unitized wheel bearing assemblies.
aquartlow- Posts : 168
My 99 superduty was doing same.Tie rod end bad.
