Tunnel Ram and Kick Down linkage
Tunnel Ram and Kick Down linkage Empty Tunnel Ram and Kick Down linkage
Post  Daytonatunnel October 22nd 2013, 2:55 pm
Anyone using a tunnel ram and have kick down linkage (C-6)? Looking for ideas on how to make it work, if at all.
Daytonatunnel
Daytonatunnel
Tunnel Ram and Kick Down linkage Empty Re: Tunnel Ram and Kick Down linkage
Post  kim October 22nd 2013, 3:55 pm
How are the carbs mounted?
With the cross mount set-up I have on the car, the throttle cable is attached at about the same point it would have been on a stock 5.0 Now I have a custom (build it yourself) Lokar cable assembly, but even with that, I would think the cable set-up I used to have with the C6 would meld right in. No kick down on a manual shifted Glide.
Even if your cabling off of inline mounted carbs, I would think LOKAR can set you up with cable lengths to allow a kick down cable.
kim
Post  Daytonatunnel October 22nd 2013, 8:23 pm
Thanks for the reply. I'll check into the Lokar options. I'm not interested in a manual valve body, hence the question. Side note, it's an Offy with inline 600's.
Daytonatunnel
Daytonatunnel
