C-6 wont shift untill high RPM
My trans has been rebuilt buy a good trans man it shifts great from 1st to 2nd but you have to turn about 4200 for it to shift into drive.once it shifts it shifts firm and im running about 55 if i back off the gas any it downshifts right back to 2nd. Trans does not have a kickdown hooked up.
capncruncher1965- Posts : 131
Re: C-6 wont shift untill high RPM
capncruncher1965 wrote:My trans has been rebuilt buy a good trans man it shifts great from 1st to 2nd but you have to turn about 4200 for it to shift into drive.once it shifts it shifts firm and im running about 55 if i back off the gas any it downshifts right back to 2nd. Trans does not have a kickdown hooked up.
Governor stuck, modulator valve bad or wrong one the modulator pin , or valve sticking . check vacuum going to the modulator valve. Kick down or throttle valve stuck in valve body.
whitefield- Posts : 2244
No kick down hooked up
Dont have a kick down hooked up think that is the problem? Im going to check the vacuum to the modulator tommaro.if it has vacuum which modulator should i use. Thanks for your reply
Sounds like a vacuum issue . Either no vacuum . Make sure vacuum is full manifold vacuum.
Did see similar with a C4 that was hooked to ported vacuum
Gregaust- Posts : 626
I wouldn’t waste my time Just take it back and make the guy fix it if you paid for a rebuild it should be right.
stanger68- Posts : 500
Got vacuum.
Replaced all the rubber hoze from carb to modulator it has vacuum for sure now will test drive tommaro to see if that fixed it
capncruncher1965 wrote:Replaced all the rubber hoze from carb to modulator it has vacuum for sure now will test drive tommaro to see if that fixed it
Must be FULL manifold vacuum from the intake , if it is on the carb ensure it is NOT ported
Got it fixed
Put new vacuum hoses on it turned the screw in the modulator qutar of a turn out and bingo shifts perfect. Thanks guys for all your help and replys. Love this website
» FORD / MERCURY C-6 Floor shift axle / shift lever
» Does a high volume oil pump necessitate a high volume oilpan?
» WONT GO INTO REV!!
» 78 F150 460 ENG Oil Pan Wont Come Out
» 55 staight axle swap 02 ranger ifs donor truck
