Ladder bars on the street? Pros/cons?
+8
Tore
Kens429
bbfstang
70429scj
RapidRuss
Greg_P
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
My patience with the cal-tracs system is worn VERY thin. I'm gonna give them one more chance after adding additional front suspension extension..... if they do not work, I'm considering ladder bars with floaters and leaf springs.
I have heard that ladder bars are not good on a street car. What's the real scoop from the guys that know?
Thanks,
Greg
Thanks,
Greg
Greg_P- Posts : 1009
Re: Ladder bars on the street? Pros/cons?
I think by now you probably know my opinion already . They just aren't the best idea if you truly want to "drive" the car hard on the street. But if you don't mind having to constantly watch how you drive it on the street (taking corners, going into/out of parking lots & driveways) they can work on the street.
The housing floaters will probably be the biggest pain in the ass of the whole deal having to keep them clean & greased. When Duane had his yellow 69 Mustang on the street he used the old Moroso "floater" style ladder bars. They were a decent compromise for using a ladder bar on the street with leaf springs and not having to deal with an actual housing floater. The down side with the moroso setup was the leafspring still centered the housing (instead of the ladder bar) since there was no rod-end on the front of the floater ladder bar.
DILLIGASDAVE- Posts : 2262
Just to point out another option (although the "books" say it won't work) of ladder bars & leafsprings without a housing floater.
Over the years I only know one guy that was really able to make the setup work well without the floater. Since you run at the Denton track you might know him or his brother, David Painter or his brother Richard. Years ago David had an early Mustang with a Cleveland/Jerico combo that some how he was able to get to hook real well for years without using a floater with the ladder bars & leafsprings. And for years all the local "experts" told him he was stupid for not using a floater because the ladder bars & leafsprings were binding against each other hurting his 60 fts & ET's. Finally one year someone talked him into letting them install floaters........and afterward all the car would do is spin it's nuts off & it slowed down.
In the end I feel that one possible reason his car worked so well without the floaters is since the rear suspension was in a bind it might have actually helped by slowing/calming down the initial hit a given amount. And less initial hit might have been what his car needed all along since it was a violent clutch/Jerico car.
Not saying it will work, just that I have seen it work on one car.
Whats TorinoJoe Running ?? I forget ?
RapidRuss- Posts : 334
Dave, thanks for the info.
I am curious how the bars were set up on the guy's car where the springs were still responsible for locating the axle housing side to side.
Greg
Greg
Greg
Greg,
I hate to here your done with the caltracs. I have both setups one car with caltracs and one with ladder bars.
Both are 70 torino's I'm fighting my own demons with the caltracs. The ladder bar car was bought as is. It has a old homemade type housing floater and ladder bar. It has two clamshells with zerk fittings for grease clamping the rearend to the springs. I have yet to test this setup but I can say I have seen it some older race cars using this same deal and it works very very well. I know you like to fab your own stuff so this may be a option. Maybe this will get some of the older guys to give a opinion!! New springs for the caltrac car should be here this week so I hope that it cures my hopping issue!!!!
Thanks,
Steve
Thanks,
Steve
70429scj- Posts : 348
Greg, if your talking about Duane's Mustang the leafspring was still responsible for locating the housing both side-to-side & front-to-back. This was because Moroso's 36" floater ladder bar setup didn't have a rod-end on the front of the bar. It had a 1/4" (possibly thicker) plate bracket with a long slot machined in it welded to the front. Inside the long slot rode a bushing/sleeve "roller" assembly. The front ladder bar chassis bracket attached to the roller bushing with a bolt.
So the front long slot bracket & bushing assembly allowed the front of the ladder bar to "float" forward & back, but still provide resistance to any bar up/down bar motion providing an I/C lift point.
On his car this setup did work OK for years, but they really wern't as consistent pass to pass as a normal ladder bar setup can be. His car got a lot more consistent when the car was converted to conventional ladder bar setup & coil overs. But buy then it was no longer a street driven car.
I have ladder bars under a 69 fairlane 428cj and never have had a clearance issue not sure how to post pics for my internet is limited.bars are home made though
bbfstang- Posts : 29
If your gonna do it put a good set of coilovers on it and be done IMO.
How much and how far at a time do you drive it?
Greg, I was in your boat this time last year,but worse. One major issue was too weak of a sidewall to absorb the initial hit. I also adjusted the Rancho shocks to #7. Now the tire plants and stays planted. I am using Calvert Racing 90-10 shocks which really extend fast. And they were cheap! These Torino/Falcon/Fairlane's don't work well without really freeing up the front suspension movement and using a stored energy spring like Moroso. It has been awhile since I saw a video of your car, but I do remember the wheel hop and minimal front end movement. I will help any way I can. Ken
Kens429- Posts : 109
Greg I think you know I am running the Cal-Tracs and they work great for me. I just put the Rancho-Shocks on the back last week and they work good. I am going to order some of their new front shocks and give them a try.
My back tires are shot and I am still in the 1.480s for 60 foots and I foot brake the car.
Tore
Tore
Tore- Posts : 865
Well, the car used to pull 1.46-1.50 consistently, but then I upped the power and installed a roll bar....
Now the car has gone 1.51 off the spray, but that was a one time deal. high 1.50's are the norm.
On the spray, the car generally loses almost a tenth in the 60 foot time.
We're gonna test next weekend and see if we made any progress.
It just chaps my azz that the home made springs and 10 dollar rear shocks we used to run worked better than the big $$$ calvert stuff has been working.
Greg
Greg
Ken,
Your car is just fantastic, I love it!
Off the spray the car does this:
On the spray it does this:
Hey Greg was watching the vid... what shocks do you have in the back and you said it started after you put the cage in.
Who did the cage did they put the car on stands or in stall it why the car was on the ground?
How many leafs are in the pack?
What rear shocks?
What front shocks?
Street/strip or just strip?
looks good but its not putting the weight on the rear tires like i like to see. it starts to then just hits a wall and the nose falls back down.
What rear shocks?
What front shocks?
Northwest outlaw- Posts : 962
Northwest outlaw wrote:Hey Greg was watching the vid... what shocks do you have in the back and you said it started after you put the cage in.
What rear shocks?
What front shocks?
The cage was put in by a good buddy who does race cars for a living.... Other thn that, not sure if it was jacked up or not. I do know that the removable door bars slide right in and out, so there's no preload on the chassis forward of the main hoop.
The springs are Calvert monoleafs
The rear shocks are adjustable Rancho 9000's that Calvert says to use
I have had literally a dozen sets of shocks on the front, everything from normal street shocks to shocks that have been emptied of oil and provide 0/0 damping.
It's a street strip vehicle with a lot (2200+lbs) of weight on the nose.
On the rear shocks the adj. is for rebound or comp. what is the setting on shock 10 clicks? Are the shocks to long putting a load on the spring. Sorry for all the ?s i dont know your car that well what type of bushings are you using in the spring eyes?
Hey, I figure the more questions that the experts ask me the better the chances are that we'll get the car working again..... so ask away!
The shocks have 9 clicks, and they are single adjustable.
The front spring eyes use aluminum bushings.
I thought the shocks were a little long, so I modified the shock mount to drop the lower mounting eye, about 3" IIRC.
Now with the car on jackstands and the axle fully extended, the shocks still have an extra inch of travel left before they fully extend.
Greg
Greg
how much travel do the shock have when bolted up to the bottom out. in the vid it looks like it hits on a stop and is killing the weight tran.. im going to look at the vid some more see if i can come up with some thing to look for.
I can't recall exactly what the upward travel limit of the shock was relative to the end of axle travel, but I do remember that it seemed like more than enough and I was not worried about bottoming the shock.
Greg
Greg
Do you think the chassis was absorbing some of the hit before (via twist) and now that you stiffened the chassis up you are blowing off the tires? Does the Calvert bar have two different holes at the front? I wonder if lowering the front of the bar would change the way it hits off the line. I had a buddy with a 70 Nova that used a ladder bar/slider deal and he drove the thing everywhere all the time. IIRC the ride sucked and it was noisy but it worked. Of course I am sure you are making way more power than he was. How come you don't just run some coil overs, is it a cost issue or are you after a certain rule etc?
jasonf- BBF CONTRIBUTOR
can tell you this--ladder bars and floaters/leaf spring equals bent housing.
DanH- Posts : 1081
Made some improvements this time out, and saw some light at the end of the tunnel.
Here's all four runs from last night. Each one got progressively better in all areas, 60 foot, 330, 660, and MPH.
First:
Second:
Third:
Last:
First:
Second:
Third:
Last:
That first vid gave me more to see you leaving off the brake right. I see that the car gets preloaded to the pass. side not good. Whats stall do you have in it?
Good run.
Good run.
maybe incorporate an adjustable anit-roll bar and add a good dble adj rear shock like an Afco.???
I didn't have the rear anti roll bar installed in the videos.
Calvert says the anti roll is not necessary with the cal-tracs bars.
I think the shock setting was a little too loose in the last vid, they were both on 4.
The launch I use is to preload the car with 2000 rpm and nail it at the last yellow. Footbrake only. The stall is somewhere around 3000-3200 or so.
I'm open to suggestions!
Greg
Greg
Page 1 of 2 • 1, 2
» E85 Pros and cons ?
» Pros and Cons
» Pros and cons for low tension oil rings
» Piston Out of the Hole - Pros/Cons
» Ladder bar question
» Pros and Cons
Page 1 of 2
