2 stage diagram
nitro717
yellowhorse7
Page 1 of 2
Page 1 of 2 • 1, 2
2 stage diagram
I am in need for a diagram for a 2 stage hook up with the trans break without a timer. I also need a flow guage with the quick disconnect end.
Thanks,
Geno
Thanks,
Geno
geno- Posts : 103
Re: 2 stage diagram
http://inductionsolutions.com/shop/flow-tool-and-components/is-flow-tool/
Re: 2 stage diagram
Induction Solution would be the best you could buy but I wanted something a little cheaper. Does anyone make a gauge as good as the one they sell?
Thanks richter69 for your help.
geno- Posts : 103
Re: 2 stage diagram
There is plenty of gauges available but by the time you put everything together with fittings, hose, jet adapters, etc your not saving much. I've been down that road and now use Steve's:Dgeno wrote:Induction Solution would be the best you could buy but I wanted something a little cheaper. Does anyone make a gauge as good as the one they sell?
yellowhorse7- Posts : 1382
Re: 2 stage diagram
Talked with the people at IS and was told without the case it would be $200 and to add a QD it would be back to $228. I didn't ask about taxes and shipping. There are too many people at the track flowing their systems. There has got to be a better way.
geno- Posts : 103
Re: 2 stage diagram
Sure. Use an old FP Gauge (or just a cheap gauge from somewhere), find an old jet fitting, some old hose with the correct 4/6 fitting and there you go. You don't need to have the shut off but it makes it a 1 person job then. Whatever you decide, stay with that method. As long as you compare apple to apples you will stay consistent. If you search Grainger, McMaster Carr, any GOOD hardware place, you will see that an accurate pressure gauge is 60$+. Cheap gauges don't take the "hit" as you turn on the system and they usually bounce all over the place. They aren't as accurate either; remember we deal with .25/lb FP increments here. Or at least I do...geno wrote:Talked with the people at IS and was told without the case it would be $200 and to add a QD it would be back to $228. I didn't ask about taxes and shipping. There are too many people at the track flowing their systems. There has got to be a better way.
Re: 2 stage diagram
OK yellowhorse7!!! I get the picture and you are more than right. Back to IS.. Thank you - I needed that.
geno- Posts : 103
Re: 2 stage diagram
http://m.grainger.com/mobile/search?searchQuery=dywer+digital+pressure+gauge
I like to use a digital gauge, be sure to use a snubber also to protect the gauge.
nitro717- Posts : 92
Re: 2 stage diagram
Thanks nitro717 but I have a IS on the way..
geno- Posts : 103
Re: 2 stage diagram
Hey Guys,
I was just checking in while i watch the wife and dogs sleep this evening.. LOL Thanks for the props on our flow tool. i know it seems expensive to many but is a really nice piece and is an important tool to have. Flowing a nitrous system with the same gauge the same way each time can save you a lot of $$ in the long run.. Thanks Geno for going the extra mile..
We have started to try and add some wiring info to our site to try and help guys out. Please take a look at this page and see if it will help you out..
http://inductionsolutions.com/tech-info/
Your feed back is also welcomed too guys.. Thanks again to you all.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Re: 2 stage diagram
Thanks IS but it was no help.. I need one with a two stage with the transbrake...
geno- Posts : 103
Re: 2 stage diagram
OK, let's see if we can still help ya figure this all out. You are looking for a two stage, with a tranny brake interupt. How are you going to be activating your second stage ??geno wrote:Thanks IS but it was no help.. I need one with a two stage with the transbrake...
SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Re: 2 stage diagram
I would like to activate the second stage with a button. Would not want to put it on timers or any other way. Either on or off.
Thanks,
Geno
Thanks,
Geno
geno- Posts : 103
Re: 2 stage diagram
So just wire the switch in where the timer is.geno wrote:I would like to activate the second stage with a button. Would not want to put it on timers or any other way. Either on or off.
Thanks,
Geno
Re: 2 stage diagram
Its fairly simple basic electronics, I dont know how to post a pic of a drawing though..... and my handwriting is too terrible to read lol
Re: 2 stage diagram
yellowhorse7 and richter69, please bare with me. I am a jet engine mechanic and not an electrician. The relays that I have all have different colored wires from the same numbered connections. I have saved and scraped to build this motor that only runs 5.74 in the 1/8. I can't beat anyone. I need to be in the 4.90 bracket just to be competitive. I have never ran nitrous in my life and I don't want to blow my motor by hooking up something wrong. There is too much money involved. A NC relay placed where a NO should have been placed may destroy what took me a year to build. PLease help me.
geno- Posts : 103
Re: 2 stage diagram
man thats a lot to pick up, a simple plate slapped on is not gonna get you there and prolly tear up some stuff in the process.
need more details on entire build.
Re: 2 stage diagram
The motor is a 532 with super cobra jet heads with extensive work done by Mr. Evans. I ran the motor with those heads and then switched to a set of stock P-51s and the car slowed down. Back to the SCJ heads. Are you saying that I can't drop .8 with an edelbrock victor 2 stage system? It's a D1VE block filled to the water pump holes. Four bolt caps, scat crank.eagle rods and an 801 lift comp cam.
geno- Posts : 103
Re: 2 stage diagram
takes a hell of a lot to drop that much at that level, no just in power but chassis wise also.
Re: 2 stage diagram
The car weights 2700 pounds with me and race ready. I bought the glide from STHAZLET with the best stuff that could be put in one. Th rear is a nine inch with 4.56 gears on a 13x31 slick. the car has ran 8.98@ 149.5 MPH in the 1/4. Do I need to contact IS for a fogger?
geno- Posts : 103
Re: 2 stage diagram
that would be a good start, the lightweight car will make it easier.
what kind of stuff is good stuff?
gear gonna need to be swapped, converter better be on point.
Re: 2 stage diagram
I leave at 5500 rpm with a 60' of 1.28/ 1.30. The wheelie bars barely touch. What would I get if I could hook this 2 stage to this motor???
geno- Posts : 103
Re: 2 stage diagram
what kit do you have?
Re: 2 stage diagram
I have the Eldebrock 2 stage Victor. 500 hp total.
geno- Posts : 103
Re: 2 stage diagram
I ran some numbers your gonna need to gain approx 450-500 hp.... thats doable with a single direct port from IS......... i have no idea what cam you have, what the heads flow etc.
Imo thats gonna be a lofty goal with your current setup and the parts you have wont live long trying to do it.
Page 1 of 2 • 1, 2
» stage stacking
» Pleas post pics of your Nitrous Engines !!!
» Anyone have a wiring diagram for a 2011 F250 SD ... FN draw...
» Is this a 2 stage plate
» 2011 F250 PCM/Radio Circuit Wiring Diagram 6.2L gas NEEDED
Page 1 of 2
