97 Mustang 564"
yellowhorse7
Tony M
dtimmer
97 Mustang 564"
I am in the process of building my 97 mustang. Should be ready for spring next season. It is stock suspension on a 29.5" x 11.5". For the first year it will most likely get bracket raced and some open comp racing. Also some local street cruising, it is a power windowed street car after all! After the first year plan is to put a single stage fogger on top. I will update more as I get more done.
Engine:
564"
a460 block
weisco pistons 4.650 bore 11.4:1 compression
eagle 6.800" h-beams
scat 4.150" 4340 crank with boss snout
Ford SCJ heads flow 420@.850 & 265@.850
rockers will be T&D 1.8 ratio with a custom one piece stand made by me
camshaft is undecided right now
6 stage dry sump
sheet metal tunnel ram with two 1150 quickfuel carbs
Trans will be a TH400, cage is currently only certed to 8.50, lots of other go fast parts.
Ignore the front runners below! They are only on there so I could move it around lol. Also the single carb intake was
replaced by the tunnel ram below.
Engine:
564"
a460 block
6 stage dry sump
Re: 97 Mustang 564"
Wow ! Nice looking ride.
Tony M- Posts : 479
Re: 97 Mustang 564"
Nice. Who did the front tube work?
yellowhorse7- Posts : 1382
Re: 97 Mustang 564"
Looks good...........
Re: 97 Mustang 564"
That's some fine looking junk right there
Mike R- Posts : 1381
» complete orginal 77 mustang ll,302 auto,t-top trade for newer mustang, can be roller
» 1990 mustang GT / 1985 mustang GT 460
» 70 mustang 9 inch into a 73 mustang body
» 1993 coupe mustang 5.0 $6500.00 / 1988 mustang coupe body $900.00
» 13-1 472 mustang
» 13-1 472 mustang
