Carb work/repair needed
nuclearcobra
JBR-3
Last edited by JBR-3 on February 22nd 2020, 1:51 am; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Re: Carb work/repair needed
Check AED in VA. www.aedperformance.com 804-271-9107
nuclearcobra- BBF CONTRIBUTOR
Those studs are Loctited at the factory upon manufacture.
Heat it to over 300 degrees and it will melt the Loctite and come right out.
Carburetors done with a finish like new and other repairs are NOT inexpensive, (as it is a TIME thing), unless you do it yourself.
New baseplate would be cheaper.........
kim- Posts : 700
JBR-3- Posts : 266
Ebay lot of holley parts cheap.kim wrote:New baseplate would be cheaper.........
supervel45- Posts : 4498
Buy a Holley book and read it until you understand the basics .. A friend recommended this to me when I built my first hot rod..... You won't regret it... Good luck.
Dave C.- Posts : 1268
where you located?
Daniel Boshears out of North GA does some nice carb restorations.
Last edited by JBR-3 on February 22nd 2020, 1:52 am; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Some shops are for perfomance only I think, and some are geared to muscle car restoriation type work. Don't know how many will do both. There are all kinds of new coatings out that you could apply yourself, some of them used on firearms refinising, like Duracoat and Ceracoat, ect. you may want to consider, as well as some of the other industrial paints as well. I guess what I am saying, it depends what your after, and how much you want to spend. The poster that mentioned getting the carb book and learning how they work, made a very good suggestion. I did, years ago, with the Holleys, and it was worth every penny, in the long run.
» 1996 E4OD with a carb engine. Can it work
» What size carb?
» Bigger carb or bigger headers opinions needed
» will tfs A460 heads work on my d1ve block ? or do they only work on the race blocks
» Getting ready to pull the 429 CJ...Need advice!
» What size carb?
