1996 E4OD with a carb engine. Can it work
I want to pull the EFI engine out and repalce with Cj headed carbed engine. I can transfer the CPS, ETS, IAT, and TPS from the old engine to the new one and can use a O2 simulator in place of the sensor in the header. Seeing as the trans runs off standards maps I would think it should act OK. Going in off road truck with 42" rubber, 5.13 diffs.
paperman- Posts : 88
Re: 1996 E4OD with a carb engine. Can it work
I would think that you would be better off running a stand alone trans controller. It would eliminate all that extra wiring and take the ECM out of the picture. I think all you need is a TPS to run a stand alone system. Simpler I think. Good luck!
jeffgfg- Posts : 338
ive done it... ran pretty damn good.im going to do it all over again on a 1st gen lightning also.
torino501- Posts : 417
» How much crap to make a E4OD work behind a towing 460 based engine??
» 1996 E4OD for 460 4X2
» Boat engine carb convert to drag engine
» Carb work/repair needed
» Will Fox body Kooks headers work with engine mounts?
