Project falcon 393
+8
Dave C.
61coon
Mustang-junky
whitefield
johndickjr
12 posters
Project falcon 393 Empty Project falcon 393
Post  johndickjr November 24th 2013, 11:23 am
well my tranny need to be redone but to get it out i had to pull the 302 motor , after 3 hours of fighting to get header bolts off i decided in no way i am doing this again , so i picked up a mustang 2 front-end stuff, and decided to build my 393, since they car was running 11.50s in 1/4 mile and 7.20s 1/8 mile with no cage on 100% stock 1962 suspension on 4 wheel drum brakes to..lol i am upgrading the whole car, the 393 just kinda fell in my lap, at this time i have a nice machined 351w roller block thats .030 over with all new cam bearing and main studs, new 3.85 crank, and eagle h beam rods, just picked up the mustang 2 fronted stuff last night and a set of ross pistons, i have under $250 in everything right now, parts just seem to keep coming my way for cheap, ill keep this updated threw out the build with lots of info and pic on putting mustang2 front end on a falcon, headers used, etc..
johndickjr
Project falcon 393 Empty Re: Project falcon 393
Post  whitefield November 24th 2013, 12:09 pm
johndickjr wrote:well my tranny need to be redone but to get it out i had to pull the 302 motor , after 3 hours of fighting to get header bolts off i decided in no way i am doing this again , so i picked up a mustang 2 front-end stuff, and decided to build my 393, since they car was running 11.50s in 1/4 mile and 7.20s 1/8 mile with no cage on 100% stock 1962 suspension on 4 wheel drum brakes to..lol i am upgrading the whole car, the 39*3 just kinda fell in my lap, at this time i have a nice machined 351w roller block thats .030 over with all new cam bearing and main studs, new 3.85 crank, and eagle h beam rods, just picked up the mustang 2 fronted stuff last night and a set of ross pistons, i have under $250 in everything right now, parts just seem to keep coming my way for cheap, ill keep this updated threw out the build with lots of info and pic on putting mustang2 front end on a falcon, headers used, etc..
Sounds like you have a plan,good luck with it.
If you need anything let me know . I have a few parts for the 351W intakes camshafts pushrods ect
whitefield
whitefield
Post  whatbumper November 24th 2013, 1:15 pm
I have a set of tfs-r 225 heads that are cnc ported that are ready for valves and springs if that would work with your pistons.     We made 675hp with these on a 370ci 10:1 motor.
Post  Mustang-junky November 25th 2013, 10:00 pm
I have a turbocharged 393 in my '79 mustang. The thrust on my 351 crank got wasted, I already had some nice H-beam rods, so I went with the 393 too. It did not make sense to put money into another 351 crank.
Sounds like you have a nice project going.
Jess
Mustang-junky
Mustang-junky
Post  61coon December 9th 2013, 8:28 pm
How's the frontend replacement going?
61coon
61coon
Post  johndickjr December 22nd 2013, 1:51 pm
61coon wrote:How's the frontend replacement going?
stopped jacking with the stock m2 stuff, picking up a rod and custom m2 cross member in few weeks,made a deal on a super vic intake , will get that next week, its for a dominatoer carb
johndickjr
Post  johndickjr December 28th 2013, 6:28 pm
test fitting the 351w today, no way am i going to do this with these dam towers, ill spend the $$$ and get the rod and custom cross member,
Project falcon 393 H3gf
Project falcon 393 Uepv
Project falcon 393 5ika
johndickjr
Post  dfree383 December 28th 2013, 7:07 pm
Miles of room..... cheers
Post  johndickjr December 28th 2013, 7:15 pm
dfree383 wrote:Miles of room..... cheers
about 2 inches, camera is deceiving
johndickjr
Post  dfree383 December 28th 2013, 7:17 pm
Won't be that bad.
Post  whitefield December 28th 2013, 9:55 pm
Tubular Automotive have the headers for the 351W swap using stock front suspension . Here is there number
617-878-9875
whitefield
whitefield
Post  whitefield December 28th 2013, 10:10 pm
Here is something else that might help you with your build .
http://www.rrs-online.com.au/shocktowerproducts.php
whitefield
whitefield
Post  johndickjr December 29th 2013, 11:07 am
dont want to use the stock front suspension with shock towers, 1950 tech and drum brakes, im ordering a rod and custom cross member tomorrow
johndickjr
Post  Dave C. December 29th 2013, 11:19 am
If you're putting a cage in it ,take a look at a strut set up.... They don't require a cross member that's gonna get in the way.
Dave C.
Post  johndickjr December 29th 2013, 12:10 pm
Dave C. wrote:If you're putting a cage in it ,take a look at a strut set up.... They don't require a cross member that's gonna get in the way.
the mustang2 swap uses fox body mustang headers, i want the shock towers gone, the rod and custom cross member is a direct for made for the 1962 falcon, its under $300, i have the other parts
johndickjr
Post  whitefield January 20th 2014, 9:06 am
Update ?!
whitefield
whitefield
Post  johndickjr January 20th 2014, 9:41 pm
whitefield wrote:Update ?!
not using mustang 2 front end, funds just are not there for it, waiting on crites headers
johndickjr
Post  whitefield January 20th 2014, 10:16 pm
I understand that ! did you get your motor done and trans ?
whitefield
whitefield
Post  johndickjr August 24th 2014, 6:44 pm
crites headers did not fit my heads, i ended up using headman headers for a 1964 351w mustang, just about ready to build motor , the last 2 weeks has been 95-100+ degrees mixed with my 65 hrs a week of work and 3 nights of school, im either wore out or to hot
johndickjr
Post  whitefield August 24th 2014, 6:51 pm
johndickjr wrote:crites headers did not fit my heads, i ended up using headman headers for a 1964 351w mustang, just about ready to build motor , the last 2 weeks has been 95-100+ degrees mixed with my 65 hrs a week of work and 3 nights of school, im either wore out or to hot
Lol ! I understand that .
Thanks for the update
whitefield
whitefield
Post  whitefield October 11th 2014, 4:57 pm
[url=Project falcon 393 Th_Huntsville6March2010Brent_Mikerace]Project falcon 393 Th_Huntsville6March2010Brent_Mikerace[/url]
John these two passes were in march and with a 9.5'' 4800 PTC converter 6.84 passes for both cars.
whitefield
whitefield
Post  johndickjr October 11th 2014, 5:24 pm
car with no cage and a iron head 302 and stock leaf springs was 2400 lbs, now it has a 351w with iron heads, a 8 point roll bar , and ladder bars with coil overs, maybe around 2700 now, i know the ladders bar setup was lot lighter then the heavy ass leaf springs
johndickjr
Post  whitefield October 11th 2014, 10:21 pm
You have any pics of the car since you have upgraded ?
whitefield
whitefield
Post  johndickjr October 12th 2014, 10:15 am
Project falcon 393 0315141555c1_zpsa13e68c4
Project falcon 393 Camera1111_zps299b8994
Project falcon 393 0315141555b1_zps5ebbe228
Project falcon 393 09061415191_zps7f70cd53
johndickjr
Post  whitefield October 12th 2014, 9:39 pm
Keep us posted on hooking an 8" tire with ladder bars.
whitefield
whitefield
