Anyone Using Infrared Heat For the Shop ?
Wes Littrell
Dave C.
I'm gonna buy a heater for my 30x50x12 insulated shop. It needs to be electric or propane powered. Thinking about buying Infrared. Asking for suggestions . Thanks.
Dave C.- Posts : 1268
Re: Anyone Using Infrared Heat For the Shop ?
I'd like to know this too.
whatbumper- Posts : 3024
its warm and toasty in my shop lol
I/R is the way to go IMO
schmitty- Posts : 4538
I installed it in my last garage but it was powered by Natural gas. The most important thing is you need a good ceiling height. I had 10' which was technically too low but it seemed to work. I have several relatives that have them in their shops as well and they all really like them.
jasonf- BBF CONTRIBUTOR
I personally like a propane furnace. I've got a 30x65 shop and I leave mine on 40 at night and it was 11 degrees this morning and within ten minutes it was 65. I had inferred heat and replaced it with the furnace. The thing I didn't like was if you stood under it you cooked and ten feet away you froze until it got the shop up to temp. Also I've got a 4 ton ac unit on mine. You can't do that with inferred.
Wes Littrell- Posts : 647
Propane should be cheaper. Tried and infared once, worked good, drew alot of current, 80-100amps if I remember corectly, 230v 4 bulb. Had a high and low settting, so you could run half the bulbs if you did not need full cap. Would want propane myself if I was going to be in the shop alot in the winter.
supervel45- Posts : 4499
Infrared heating works by heating objects in the shop which radiate heat to keep the shop warm. It works best to keep a steady temperature not so much a on/off device (unless maybe you want to cook some hotdogs on the grill. lmao).Wes Littrell wrote:I personally like a propane furnace. I've got a 30x65 shop and I leave mine on 40 at night and it was 11 degrees this morning and within ten minutes it was 65. I had inferred heat and replaced it with the furnace. The thing I didn't like was if you stood under it you cooked and ten feet away you froze until it got the shop up to temp. Also I've got a 4 ton ac unit on mine. You can't do that with inferred.
I was looking at propane IR heaters.supervel45 wrote:Propane should be cheaper. Tried and infared once, worked good, drew alot of current, 80-100amps if I remember corectly, 230v 4 bulb. Had a high and low settting, so you could run half the bulbs if you did not need full cap. Would want propane myself if I was going to be in the shop alot in the winter.
We've got IR at work, not a big fan, one line starts over my stalls and it's like working in a broiler. Hot on one end cool on the other, constant battles over the thermostat. The back shop is heated by 2 hanging furnaces, much faster recovery time after the doors are opened. I'd rather work in the back. At my last house I heated the garage with wood and used a couple of fans to move the air around, once the concrete was warm it stayed pretty even.
Mike R- Posts : 1381
Look into a waste oil furnace.
Darrin Gorham- Posts : 180
Aren't the IR heaters designed to heat the floor and other objects in the shop?
Back in the early 90's I was doing some sideline work for the gov't, and we had a shop that we pulled main battle tanks into in the middle of winter. The shop had I/R heat in it, and the tanks would come in with a layer of snow and ice on them, and within a couple of hours we were able to work around them comfortably. I/R heats objects, and has a fast warm up time for a shop that is pulling items in and out a lot in cold weather. You can get a waste oil furnace or I/R heater, that burns old oil, if you have a supply that is handy. Nat gas, is best, but propane will work too. Do not try to heat large areas with electric I/R, it requires a huge service to supply the needs. Another option is I/R with a forced air unit combo. That is the best of both worlds.
Ok guys, thanks for the suggestions .
Sorry my bad. I thought you where comparing the gas vs. electric. The one I had, 2ft or so gas filled bulbs, and may have been Zeon gas, or some such, been a long while back.whatbumper wrote:I was looking at propane IR heaters.supervel45 wrote:Propane should be cheaper. Tried and infared once, worked good, drew alot of current, 80-100amps if I remember corectly, 230v 4 bulb. Had a high and low settting, so you could run half the bulbs if you did not need full cap. Would want propane myself if I was going to be in the shop alot in the winter.
» Anybody here have a concrete block wall shop they heat?
» Shops With Propane Infrared Heaters
» Setting up new shop What shop equipemnt?
» I Have Proved
» Heat....
» I Have Proved
» Heat....
