Shock tower question
qtrhors1
Cars: 66-67 Fairlane 67-70 Mustang 68-69 Fairlane/Torino
How many of you guys with the 385 series engines swaps in these cars did this without out the shock towers cut back? Do you have any regrets or special insider info on going this route?
Tim
Tim
qtrhors1- Posts : 14
Re: Shock tower question
the center plugs are fun! i learned to like the plug socket that used an open end wrench and a piece of 3/8 fuel line to put the plugs in.
The header tubes that turn straight down right at the exhaust port are a great horsepower killer if you're trying to keep performance at a safe level.
maverick- BBF CONTRIBUTOR
and soooo much fun to put on! if i was gona cut on a stock mustang tower i'd cut it OFF!maverick wrote:The header tubes that turn straight down right at the exhaust port are a great horsepower killer if you're trying to keep performance at a safe level.
The '69 Mach 1 I did also got a rack & pinion rear steer conversion. The right side tie rod posed a little challenge...2 primary tubes went above it, 2 went below. Individual tubes, bolt on collectors...also caused hyper-extension of my vocabulary.
not to hi-jack
i just picked up a 70 fastback roller that needs flooors
sold the foxbody kept engine and tranny for the fastback .....going to do 4link or ladder bars
but have same questions on these front ends with shock towers it looks small and tight for bbf
5pointslow- Posts : 1408
Yep everthing is tight.. Not only the headers but the drivers side valve cover is all over the master cylinder. Hooker makes a set of headers for it though.
Dave C.- Posts : 1268
shock tower info
My car had the towers in tact with the 466 but when I rebuilt the engine I cut them and I changed my master cylinder to dual and put the pedal about 1" to the left of the steering column. Here is the link to the article I used to attack the towers and a link to my build with pics. I apologize if I'm not supposed to post links from the other ford site, just wanted to share some info.
I'm glad I did the cut it makes things a lot easier.
Link for shock tower cutting that I used. http://www.fordmuscleforums.com/susp...ck-towers.html
Link to my build with pics of before and after the cut. http://www.460ford.com/forum/showthread.php?t=160051
I hope this is helpful
-Jeff
-Jeff
blu69MachI- Posts : 59
Mine is notched. My hand represents about where the original was.
70FB- BBF CONTRIBUTOR
Thanks guys!
Tim
Tim
» does anyone manufacture recessed shock towers
» 1969 shock tower braces
» Rear shock question
» need shock tower measurements/ Kaase
» Belly Pans on Shock Tower Cars
