Ky @ Bowling Green today
+14
capri-sun
David Willingham
RapidRuss
KY JELLY
8liter
56Tbird
18 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Ky @ Bowling Green today
Randy, I see where you went to a spragless TC. Were you breaking the sprag deal often? Did you slow down with the spragless? I have a friend with a 1991 GMC Syclone truck with a twin-turbo 311" V6. It has a PG and we have been sneaking up on the boost and this weekend, we broke the sprag in it. The truck has 8 passes on it. This truck should run 4.80's @ 3000 lbs when we get it to full boost. Right now we are at 21 lbs and have run 5.25 @ 132. I know David Cole has had some trouble with the sprag and I may as well. I need to make a decision if I want to get a spragless right off the bat or not.
Thanks,
David
Thanks,
David
I wouldn't fool with adding the nitro............and i know that was on the old motor not this one. The M5 is a "safe" way to get some extra pop from the fuel.
I broke/hurt the sprag several times in my old hardtail car with both BTE and PTC converters. With the American car I went to a spragless. Great move. No more problems and it works great. Mine is a Hughes 9" GM96 016scn1.David Willingham wrote:. I know David Cole has had some trouble with the sprag and I may as well. I need to make a decision if I want to get a spragless right off the bat or not.
Thanks,
David
That was the first problem I had had with the converter. It was 8 years old and it was originally built for a 466 with dove c heads. It also had an aluminum stator so I can't complain about it breaking. They said the burnouts are what breaks the sprags.
I can't tell any difference in et , the car duplicated the run made 2 passes before the converter broke , but it had the shorter goodyear tires on it before so its not exactly an apple to apples comparison. I would just go spragless right from the get go , I have not talked to anyone that has changed and noticed a big difference.
Dowwwwn Nozzles
Dowwwwn Nozzles
KY JELLY- Posts : 1530
I went from a 8" convertor to a 9" spragless .The only difference it made was dropping the RPM 800 RPM in the traps. Now I can run 1/4 mile with the same gear.
56Tbird- BBF CONTRIBUTOR
KY Cherrie Pie
NICE run Randy, especially the long air
David, Spragless would be a good idea with your application.
D. Sea- Posts : 2768
Well, it turns out my buddy had a PTC spragless TC. He took the trans out today and found a broken stator support on his Rossler PG.
David Willingham wrote:Well, it turns out my buddy had a PTC spragless TC. He took the trans out today and found a broken stator support on his Rossler PG.
That's the first thing they asked me to check when I though I was having converter issues.
KY JELLY wrote: but my safety timer to keep the transbrake from being engaged after launch did not have enough time to reset and it launched soon as I hit the throttle and that was my quickest 60' of the day.
That's really haulin' the mail there, good show.. What are you using for a safety timer? I need something like that.
Thank's Doug , its a feature built into the delay box you , can set how many seconds you want for safety . I can't think of a good way to do it without a delay box unless you wired it to use 2 buttons to arm the transbrake ?
i guess i miss something in the thread ........ what is the safety timer for ???
Bruno,
It's so you don't accidently re-engage the trans-brake during a run or a pass.
Uncle Charlie
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
Bruno ,the safety timer is for after you leave the line in low gear, if you bump the t-brake button accidently it can't apply the brake for x amount of seconds. It gets real ugly when you see somebody hit the t-brake button right before the shift, then it locks the t-brake at 60 MPH. I used to use mine ,but after having the issue Randy did , I either use mine with hardly any time in it or nothing at all. I want to be able to rekey the button if needed in the stage lights.
I don't know if thy still make it, but you used to be able to buy a stand alone transbrake lockout for the guys that didn't run a delay box. It was made by either Dedenbear or Biondo, Just a small box with an adjustable timing that prevent the transbrake from working for X amount of time.
All of the newer digital delay boxes have them built in. I've got mine set for 3 seconds. By then I'm already in high gear and my transbrake doesn't work in high.
Great job Randy, that's cranking . Bobby Z
665 falcon- BBF CONTRIBUTOR
Page 2 of 2 • 1, 2
» Some of my pics from Bowling Green
» NMRA WORLD FINALS
» Back from Bowling Green
» Bowling Green Hot Rod Reunion-Who's In?
» NMRA ----Bowling Green ?
» NMRA WORLD FINALS
Page 2 of 2
