ARC Bottle Bracket
ARC Bottle Bracket
Has anyone tried the ARC nitrous bottle bracket with built in bottle warmer? Thinking about trying one. Thanks Randy
valleydawg- Posts : 427
Re: ARC Bottle Bracket
that is what I am using a little price but well worth it.i like to use the 110/120a/c plug in at the trailer and while I am in line I can keep the psi up if needed with the 12/24volt battery.just don't turn it on and walk away it heats up fairly quick and you have to shut it off when your bottle gets to were you want it."in other words it will be a bad Sean ....."
Larry T- Posts : 1076
» best alt bracket set up
» Low mount alternator bracket and csr water pump
» NMRA Bowling Green, KY racers...no more Bracket 1 or BK 2
» yet another reg bracket
» A/C BRACKET
» A/C BRACKET
