Head Planing
Head Planing
How much can you safely plane a D2OE-AB head to gain some compression? My heads a "clean up plane" last time, they cc'd at 91cc. The block is decked with the pistons .002" down in the hole. I suspect the heads were planed before, I had to plane my intake to get it to seal against the bottom of the intake gaskets when I built the engine.
BigRigTech- Posts : 763
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» coolant leak between head and block at head bolt location.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» Which Head?- 598 NA
» P51 Head HP gain after head port
