head gasket thickness for NOS.
How thick of a head gasket do I need for spraying 300/350hp shot of nitrous on my 598/Aheaded deal.
motor specs are as follows
4.6 bore
4.5 stroke
6.8 rod
ring down .350
piston is .005 in the hole
14 to 1 compression
flat top piston
valve reliefs -4.88cc
I currently have a cometic gasket with 4.640 bore and .040 compressed thickness. thx
4.6 bore
4.5 stroke
6.8 rod
ring down .350
14 to 1 compression
flat top piston
Last edited by deliveredfast on December 16th 2013, 10:14 am; edited 1 time in total
deliveredfast- Posts : 358
Re: head gasket thickness for NOS.
so I gather the piston is .005 in the hole?
yes. fixed itrichter69 wrote:so I gather the piston is .005 in the hole?
Id want the quench a little bigger imo w a 300-350 shot....... but honestly Id get the deal going and get to to track..... I doubt you'll wanna hit it that hard right away.
always can go through it later and make some changes...... track time might yeild some you cant see right now anyways.
get it to the track and dont sweat the little things.
richter69 wrote:Id want the quench a little bigger imo w a 300-350 shot....... but honestly Id get the deal going and get to to track..... I doubt you'll wanna hit it that hard right away.
well I have to re-ring the motor and the correct rings in it for spray so I figure may as well get everything right on this go around.
richter69 wrote:run it!!
got some coolant seeping between head and motor on passenger side. So if I gotta pull the head may as well ring it and get the right thickness gasket for quench.
deliveredfast wrote:richter69 wrote:run it!!
Have you tried re-torquing the heads? Might help stop the seeping.
DILLIGASDAVE- Posts : 2262
Don't know if this helps I spray 400 through my 557, talked to lem Evans and we went to 55 thickness, never seeped or leaked..
michealj- Posts : 78
michealj wrote:Don't know if this helps I spray 400 through my 557, talked to lem Evans and we went to 55 thickness, never seeped or leaked..
what rings are you running?
