598 cid Profiler 205 head
+31
Gary Blair
wayney
774 Super Street
gmsmkr
T-Bird88
glenevans
crittersf1
old blue
chuck
Oakley Motorsports
Brenden
Darrin Gorham
bigblok2000ranger
bosshoss
torino501
dirt_worker
yellowhorse7
psfracer
35 posters
Page 2 of 4 Previous  1, 2, 3, 4  Next
598 cid Profiler 205 head - Page 2 Empty Re: 598 cid Profiler 205 head
Post  Mark Miller January 13th 2014, 1:17 am
Paul,those are some nice looking heads,intake and carbs good luck on the build should make some big power!!!
Later Mark.
Post  psfracer January 15th 2014, 12:12 am
THanks!
I got a new intake today.  New meaning new to me.  Its a Hogan's intake, and the runners are much shorter vs the original one I got with the cylinder heads.  It came off of a 638 and the guy said it liked 6000-8200, which is what I need for my build.
psfracer
psfracer
http://www.psfracer.com
Post  psfracer November 7th 2014, 10:17 pm
Getting the final small parts for this one.  Thanks to Keith Fulp for helping me get some replacement parts for my Danny Bee belt drive.  Should have some great updates soon. Added a few pics to post #1.
psfracer
psfracer
Post  old blue February 20th 2015, 11:00 pm
this is one wicked build I cant wait to see the results, good luck with your build
old blue
old blue
Post  crittersf1 February 20th 2015, 11:50 pm
I want to see some numbers. The car literally flew the last time I saw it.
crittersf1
crittersf1
Post  old blue February 22nd 2015, 7:58 pm
yea me to this is one bad a car
old blue
old blue
Post  glenevans March 4th 2015, 2:33 pm
Hope we will see you (and your car) at the Las Vegas race in November, was fun last year. - Glen
glenevans
Post  T-Bird88 March 6th 2015, 1:30 am
Do you have any numbers to share yet? I'm curious as I have a very similar motor that I will be putting on the dyno within a few weeks. Will be interesting for me to have a motor like this to compare to. Ran a few test passes with mine last year but was still in the process of tuning before our racing season ended.
Nice car by the way, very cool combo.
T-Bird88
Post  bruno March 9th 2015, 4:39 pm
come on Paul, get off the mountains and report back to us !!!!
http://WWW.CKRME.COM
Post  psfracer March 12th 2015, 2:32 am
I will definitely post up the dyno sheets and a lot more info when the time comes.
Here are the basic cam specs:
Intake 288 @ .050 -- lift .945 (1.80 rocker ratio)
Exhaust 306 @ .050 -- lift .925 (1.80 rocker ratio)
118 LSA
Was considering aluminum rod but ended up going with Oliver steel rods. Almost there---all though its been on the back burner since I missed the 2014 SCSN. But it will be out soon.
Here are the flow numbers. The valve job we went with sacrificed top lift flow numbers but increased the mid lift numbers nicely. I am not sure what the "range" numbers signify.
598 cid Profiler 205 head - Page 2 ProfilerFLownumbers
psfracer
psfracer
Post  gmsmkr March 12th 2015, 9:27 am
This thing needs wings,,, bad azz build
gmsmkr
gmsmkr
Post  old blue March 16th 2015, 10:11 pm
Man I'm looking forward to seeing these numbers. this is one bad set of wheels
old blue
old blue
Post  psfracer December 31st 2015, 1:28 pm
Ok this is finally coming together now.  Since I missed the SCSN in 2014, I put this on the back burner while buying a new home, got back into guns, photography, hiking, etc.  But now I have the racing bug again so.......
Right now just waiting on head studs for the "C" style 18 bolt head.   Kaase has them on back order from ARP.   Anyone know where I could get something that would work? Other than that, short block done, bushings installed in lifter bore for "keyway" lifters--as in there are no bars between each pair of lifters.  Instead there is grove in each bushing that lines up with a pin on the lifter to keep it from rotating.   I will also have to go with a belt driven distributor on that front mount because of the manifold.
On the intake manifold, having a new spacer being made (between the bottom and top pieces) to an inch tall to increase the plenum a little.   Will also be running water lines to each side of each head.   Also need to set up the oil lines and make brackets for the external oil pump.   Hopefully this will see the dyno sometime in February.
598 cid Profiler 205 head - Page 2 598%20CID%20BBF%2012-2015
598 cid Profiler 205 head - Page 2 598%20CID%20BBF%20%202%2012-2015
^^^wrong head gasket I know.
Picture of one of the Oliver Rods:
598 cid Profiler 205 head - Page 2 Noname-24%20copy
Valve springs with 400lbs on the seat, 1100 open.  Titanium retainers, Jesel rockers.
598 cid Profiler 205 head - Page 2 Noname-25
psfracer
psfracer
Post  windsor January 19th 2016, 10:38 am
Giggity! Give me the funny feelz... bounce alien
Post  774 Super Street September 16th 2016, 1:31 pm
Has this engine made it to the dyno?
774 Super Street
774 Super Street
Post  old blue September 16th 2016, 1:39 pm
Any updates, i got a similar build but with c-heads
old blue
old blue
Post  psfracer September 20th 2016, 11:38 pm
Almost there.   I am having a spacer made for the manifold (to go between the base and the top) to increase plenum volume.  A couple other odds/ends--should have dyno numbers by end of this month.
psfracer
psfracer
Post  psfracer October 14th 2016, 11:57 pm
Getting closer, hopefully will be on dyno next week. Will have the go pros video -- one hopefully right above the engine.
598 cid Profiler 205 head - Page 2 Boss%20598%20Engine%201%20Oct%2016%20web
598 cid Profiler 205 head - Page 2 Boss%20598%20Engine%202%20Oct%2016%20web
psfracer
psfracer
Post  bruno October 15th 2016, 1:31 am
1286 .... and im sticking to it !!!
Post  psfracer October 31st 2016, 8:49 pm
Well had first shakedown pull after making sure everything was as it should be, this motor was already passing the peak power level of the old motor at only 5700 rpm......hahaha. We only pulled it to 7500rpm, we are going to do a couple adjustments plus add a plenum spacer and take it to 8000 rpm. I will post the final dyno numbers and have a video here in the next couple of days.
psfracer
psfracer
Post  dfree383 November 1st 2016, 8:31 am
Ok how'd it do?
Post  psfracer November 2nd 2016, 1:28 pm
Well we hit a little bump in the road. We don't like what the oil pressure was doing in the higher rpm ranges, so they are going to put .018 restrictors in -- plus send the brand new moroso oil pump back to get looked at. This motor has the Jesel keyway lifters in it, and there was another thread on here discussing if people were running those wide open or with restrictors. Well we are going to run restrictors.
Because of that we still have not made an 8000 rpm pull (why would we if we didn't like the oil pressure). So it looks like by the time the restrictors are put in and the pump comes back from Moroso it will be a week or two.
So far we are at 1144 @ 7500 rpm and we have 500 more rpm to go as well as adding the plenum spacer. I think it will be 2.0 hp / cubic inch when its done.
Honestly, based on what I have read, I am not seeing much of a difference between this head and the C460 head. However, to be fair, I got these heads from a guy where the exhaust ports were done with nitrous in mind, and this of course is an N/A application, so maybe it would have been different with a brand new set of heads. We are still not done yet so we will see. I will post the dyno sheet and video once its done.
On a positive note, this combo is absolutely killing the old combo in power, throughout the entire curve from 5,000 rpm up. At some points its 250+ hp above the old combo--and we are not done yet.
psfracer
psfracer
Post  glenevans November 2nd 2016, 7:17 pm
Awesome,......... vegas race is only two weeks away!!!!!
glenevans
Post  psfracer November 2nd 2016, 7:57 pm
I will be there but not with the car.  Once i put the engine in the headers still need to be made, so i will be there but only to watch.   Mad Mad
Here are a couple pics from yesterday:
598 cid Profiler 205 head - Page 2 Boss%20598%20Dyno%20pic%205%20web
psfracer
psfracer
Post  dfree383 March 30th 2017, 10:34 am
Bump for an update
