Gear Oil
geno
Gear Oil
Has anyone used any synthetic gear oil in their rear ends. I was told by a guy at the track that the synthetic was too thin for the off line launches. Isn't 90 weight the same?
geno- Posts : 103
Re: Gear Oil
i use full syn 75 140 i get from work, its fine.
Re: Gear Oil
Thanks again richter69. full synthetic will be installed. Thank you...
geno- Posts : 103
Re: Gear Oil
we run full synthetic in everything. we like it better because in our studies it stays on everything better. (Our studies means, when we take everything apart! LOL)
I dont understand people and their opinions about oils. If you get a numerically lower viscosity oil it will be thinner. But that's not what you asked. We run 75w-90 in everything from bracket racing to pro-mod.
You'll be fine.
You'll be fine.
whatbumper- Posts : 3024
Re: Gear Oil
geno wrote:Has anyone used any synthetic gear oil in their rear ends. I was told by a guy at the track that the synthetic was too thin for the off line launches. Isn't 90 weight the same?
Not everyone at the track knows wtf he's talking about. For some guys, the price of admission makes one an expert.
maverick- BBF CONTRIBUTOR
Re: Gear Oil
maverick wrote:geno wrote:Has anyone used any synthetic gear oil in their rear ends. I was told by a guy at the track that the synthetic was too thin for the off line launches. Isn't 90 weight the same?
You could probably sell him 100yds of flight-line.
crittersf1- Posts : 521
Re: Gear Oil
In general if we are talking basic gear wear, most any type gear lube (syn vs dino) will usually work OK for a large majority of the drag/bracket cars out there. From what I have seen over the years a surprising amount of the gear wear being blamed on using the "wrong" gear lube is really the result of either (A) the gears being set up incorrectly in the first place for the car's intended purpose, or (B) using the wrong gear material for the car's intended purpose.
The bearings on the other hand do seem to look a little better over time with the synthetic lube vs the dino lube (for me anyway).
DILLIGASDAVE- Posts : 2262
Re: Gear Oil
Any gear oil will work. Gear oil has "shear property" as part of it's blend, that's what helps with the impact. I tried motor oil before synthetics were available (to me) and that don't work. Frees up rotation but doesn't protect the gears!
Dave.
Dave.
LivermoreDave- Posts : 972
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
» 460 rotor gear connecting gear bad
