C&C 325 trick flow heads
I have not been on here in months , I searched but didn't see any one using the trick flow 325 heads
Is there anyone else besides me using them ? If so can
Some one post a combo and some numbers .
10SHOTS- Posts : 587
Re: C&C 325 trick flow heads
Everybody one here has been waiting for someone to build and dyno a 325 deal.............. So far no one has posted any numbers.
I'd like to get my engine on a dyno for some numbers , I think
It could use a little more cam to
Yep.............
I have a set on the 514, they are very nice & have good flow #'s.
I have the 53400112 "mafia" intake as well, have done nothing but bolted these together
2579Lbs car
injected alky
power glide
4.56 gear
best pass so far 5.59 @125.xx (1/8th)
leaving @ 4400
shifting @ 6500 (have a small cam for this deal)
2579Lbs car
injected alky
power glide
4.56 gear
leaving @ 4400
Airflow on the CNC 325's according to TFS
This is the info I got when I talked to TFS
these test conducted @28" of water (pressure)
bore size 4.380; exh w/2" pipe
lift value.................intake flow cfm................exh flow cfm
0.100---------------------82-----------------------------58
0.200--------------------162---------------------------115
0.300--------------------262---------------------------160
0.400--------------------332---------------------------196
0.500--------------------370---------------------------223
0.600--------------------388---------------------------261
0.700--------------------401---------------------------290
0.800--------------------408---------------------------302
And yes they are jewelry...
hey bluehotrod, i was thinking about the same set up for my anglia, is prety stock dove engine the now with small cam upgrade, still on stock bolt down rockers been a best 9.97 in the 1/4, 9.2 wey a 100 bhp nos, would be great to see some dyno on a 460 with this combo. cheers jonny
jonny z racing- Posts : 50
jonny z racing wrote:hey bluehotrod, i was thinking about the same set up for my anglia, is prety stock dove engine the now with small cam upgrade, still on stock bolt down rockers been a best 9.97 in the 1/4, 9.2 wey a 100 bhp nos, would be great to see some dyno on a 460 with this combo. cheers jonny
Hey Jonny,
that is a cool ride you got there,
My pops use to have one that he ran with a SBC & a 4-speed...
nice stang m8. just sold wife,, pro street mach 1 before xmass. the green pop is my road going car, this is my track one
fitting a new flip front & new colour scheme. cheers jonny
» Trick Flow A460 360cc heads cnc flow numbers
» Trick Flow heads
» trick flow 325 heads
» Trick Flow Heads
» New Trick Flow heads for the FE
» Trick Flow heads
» Trick Flow Heads
