trick flow 325 heads
has anybody ran the CNC 325 heads yet looking for some real world numbers looking at replacing the TFS 290 heads. yes i know there is better heads out there but for a guy that has everything set up for the standard valve layout is it a good head.
muddog899- Posts : 56
Re: trick flow 325 heads
What about porting what you have?
» Trick Flow A460 360cc heads cnc flow numbers
» A Trick flow heads oil drain
» C&C 325 trick flow heads
» Trick Flow heads
» Trick Flow Heads
» Trick Flow heads
» Trick Flow Heads
