.903 and .937 same cost - why not?
.903 and .937 lifters are the same cost far as I can tell from a few different vendors...any reason NOT to do the .937 if I'm going bigger anyhow? Eliminator Premier block.
![cyclops](https://2img.net/i/fa/i/smiles/icon_cyclops.gif)
windsor- Posts : 1167
Re: .903 and .937 same cost - why not?
Are you talking tie-bar lifters? Make sure the cam people know the roller dia. before the cam is ground.
Correct, Lem, not key way.
So is it a go assuming I'm going bigger anyway?
(Assuming I don't go with the new morel hyd rollers)
Check with your Machine shop to be sure they have the .937 BBF lifter bore tooling.
CDMBill- Posts : 182
Will do indeed. Will likely use C&C close to me in Manassas. Pretty sure they have it
![Cool](https://2img.net/i/fa/i/smiles/icon_cool.gif)
» My 533 SCJ by Charlie Evans Racing
» Cost Differential 468 vs 505?
» anyone ship a 3rd member in a 5 gallon bucket?
» Cost to have Head work done?
» Cost of carbs
» Cost of carbs
