557 TFS street build 861 hp-753 tq
+17
56Tbird
5pointslow
86 coupe
stangr8cr
D. Sea
RapidRuss
Old blue Racin Team
61coon
KY JELLY
Derek@BPP
21 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: 557 TFS street build 861 hp-753 tq
61coon wrote:Smoked "Sea" Trout.............Kinda sounds good.
It's on special this weekend
D. Sea- Posts : 2768
Phantasea466 wrote:61coon wrote:Smoked "Sea" Trout.............Kinda sounds good.
You are special............. You riding the short bus down to BG ?
IDT-572 wrote:Phantasea466 wrote:61coon wrote:Smoked "Sea" Trout.............Kinda sounds good.
Don't be makin' fun of Chuck's truck, he may get "upset"
Albert wants to go,is that cool?
61coon- Posts : 1824
Hell yea you can drive and Albert can ride with you.
61coon wrote:Albert wants to go,is that cool?
Tell him to bring "Bobby"
Hot Damit not Bobby
D. Sea wrote:Oh YEAH!!!
Boo Boo wants a rematch with me and I want a rematch with YOU...
IT'S ON NOW BIATCH
Here is a copy and paste of whats posted in the general post.
Well, We had a blast as usual, It's always a good time with that group of guys and gals. They are the best.
First, the cast heads and an extra battery added 104 lbs to the car over the previous weight with me in the car.
It ran a 5.88 @ 117 1/8th mile and 9.28 @ 142 and change 1/4 mile. It just dosen't pull in the upper rpm like the Streets did . The 60 foot times went up to 1.31's from 1.26's It's a lose of torque issue i'm sure from the bigger runner size.
Mph is down also 124 before and now 117 1/8 147 before 142 now 1/4 mile. Could get more with tuning , but I don't think there is much more left .
Not bad for almost 40 year old iron. Here chevy chevy chevy,,,,,,,,,,,, lol
I just deleted my engine build on the old site, be it right or wrong, it's just not home to me anymore. I also put a post in my friends area or what ever you call it , that I am here and any one wanting to pm me will have to do it here . I left Nicks web addy on there.
I just wanted to say thanks to all that showed an interest to my build.
Thank you,
Thank you,
noticed that............screw um.
I deleted a lot of my stuff over there and brought it here too. I'm with ya Jon, screw em.
schmitty- Posts : 4538
wow
nick I don't know if i can even say how blown away i am after reading about your build. it is incredible, made my choice of engine size much easier.
86 coupe- Posts : 119
86 coupe wrote:nick I don't know if i can even say how blown away i am after reading about your build. it is incredible, made my choice of engine size much easier.
this is Blakes build not Nicks
what kind of fuel u running?
5pointslow- Posts : 1403
5pointslow wrote:what kind of fuel u running?
I lknow your trying to get an answer to your fuel question. This is my build, but it's not one for you to compare to. This engine is 15:1 compression. pistons are .0075 out of the hole positive with a .041 Ford 441 gasket. I realise this is a no no from what is usually posted, and I will advise you not to try this. .034 quench is to tight for a engine of this size and piston clearance.
It has 250 lb of cranking compression and I ran it on 112. The chambers ar polished as well as the piston tops. There are no thin or sharp edges in the chamber.
If you build a 545-557 with a flat top 72-74 cc heads 0 deck with a cam in the 275-280 @ .050 intake lobe on a 109-111 seperation you should be able to run 112. And can probably run a 200 shot of no2 if the tune is right. Myself I would probably go to 114 on the nitrous.
JMO
THANKS FOR THE KIND WORDS COUPE.................
sorry
sorry about the slip up blake, just had a bad brain fart.
gotta watch those brain farts Craig!! You'll end up with shit for brains if your not real careful! This engine is fixing to be even badder!! I'm buying it !! And we're doing some things to it,and putting it on Alky..What do you think it'll run in Tweetybird ?? We're gonna find out this spring86 coupe wrote:sorry about the slip up blake, just had a bad brain fart.
56Tbird- BBF CONTRIBUTOR
? heads
Dan what heads will you be using with this
86 coupe wrote:Dan what heads will you be using with this
Not Dan, but It will have TFS STREETS
Blake is fixing and doing a little work on my KyJelly TFS Street heads...That's where the SnakeJelly power comes into effect And there is another Player behind the scenes that we'll reveal when the time comes???
have a little "FAITH" ..........
bruno wrote:have a little "FAITH" ..........
I have no doubt Dan's turd will fly with this new bullet, after all the snake is putting it together..........
Hell it might even last more than one season.................
» 521 STREET/ STRIP BUILD
» 460 street hp
» My street car build.
» P-51 Street Build
» 460 street hp
» P-51 Street Build
Page 2 of 3
