Strongest C4 Forward Drum ??
+6
10SHOTS
Gregaust
Mustang-junky
colormebad
10 posters
Strongest C4 Forward Drum ?? Empty Strongest C4 Forward Drum ??
Post  colormebad February 19th 2014, 12:13 am
Which of the 2 drums seem to be holding up the best, between welded or the sleeve ??
Strongest C4 Forward Drum ?? 2-18-201420-00-34_zps4212ba7a
colormebad
Strongest C4 Forward Drum ?? Empty Re: Strongest C4 Forward Drum ??
Post  Mustang-junky February 19th 2014, 6:00 pm
I replaced a brazed drum with a sleeved one. Sleeved one seems to be holding up fine. Brazed one cracked and stripped out all the teeth.
Jess
Mustang-junky
Mustang-junky
Post  colormebad February 19th 2014, 6:56 pm
Mustang-junky wrote:I replaced a brazed drum with a sleeved one.  Sleeved one seems to be holding up fine.   Brazed one cracked and stripped out all the teeth.
Jess
I thought the sleeve one' was what gave on my c4' but after i got it apart it was fine, it was the pump drive gear broken in 4 places...The outer seized up and broke the drive or the drive broke and metal got around the outer...I was just doing a burnout and lost all gears....PTC says they think i just got a bad pump...I bought the pump rebuilt from transtar, it was a C5 pump, but i have ran them before on the c4's with no problem...Not sure what happened...I ordered a PA pump from jegs...
colormebad
Post  richter69 February 19th 2014, 7:27 pm
one on the left is what Ive been runming.
dont wast the $$$$$ if your combo makes the power it should you will go to a glide or get real good at putting clutches in that c4.
side note, PA stuff is junk I got two of their C4s here apart that proves it.
Post  colormebad February 19th 2014, 8:05 pm
richter69 wrote:one on the left is what Ive been runming.
I have never had clutch problems...I would put a c6 in it before i would put a glide in it...Remember! I dont mix-breed lol
colormebad
Post  richter69 February 19th 2014, 8:25 pm
My 2 speed is all aftermarket, i use whats hassel free and faster....
Post  Curt February 19th 2014, 8:46 pm
I have powerglides without any GM parts.
Post  Gregaust February 20th 2014, 6:17 am
richter69 wrote: PA stuff is junk I got two of their C4s here apart that proves it.
Quite surprising what's in them for the 1000 HP rating  Shocked
Gregaust
Post  colormebad February 20th 2014, 9:01 am
I think its the C6 pump bushing.....lol
colormebad
Post  10SHOTS March 17th 2014, 12:55 am
My brother uses the drum on the right and
Has been 5.30s with his c4 , drum holds
Clutches don't but you can make a c4
Last a little while , go to a glide and be done!
10SHOTS
10SHOTS
Post  supervel45 March 17th 2014, 1:26 am
I say this, then I will go hide. Ford Engine+Chevy trans+ 9" rear= Good race Car, Glide or TH400. C4's, C6's and TH350's only can go so for in the HP department.  Suspect By
Post  colormebad March 17th 2014, 8:02 am
supervel45 wrote:I say this, then I will go hide. Ford Engine+Chevy trans+ 9" rear= Good race Car, Glide or TH400. C4's, C6's and TH350's only can go so for in the HP department.  Suspect By
I say im provin it all wrong with a home built c4....Built ford tough with all ford stuff....And i dont have to run and hide....lol
colormebad
Post  richter69 March 17th 2014, 8:30 am
No hidin here.......
Post  the Coug March 17th 2014, 9:34 am
Jon knows he was taking his c4 out almost every weekend to work on it, I took him a glide and he put it in and hasn't taken it out in like 4 years. To you guys that are no cross breading Ford actually sold the glide to Chevy....I love the fact I can launch it and 1 click and it is done let the Torque pull it out the back door..... don't have to worry about 1,2 2,3 flare and or crappy drums and broken parts in a c4.
Post  richter69 March 17th 2014, 9:43 am
I still have the c4 its in a high 8 sec sb car though lol. Its quite happy there.
Post  supervel45 March 17th 2014, 10:51 am
I did not say a C6 would not work or that they are junk. They have their limitations is all. A built up C6 with one of Frank's valve bodies might be better than the C-4 if he is pushing some serious HP.
Post  colormebad March 17th 2014, 11:39 am
the Coug wrote:Jon knows he was taking his c4 out almost every weekend to work on it, I took him a glide and he put it in and hasn't taken  it out in like 4 years. To you guys that are no cross breading Ford actually sold the glide to Chevy....I love the fact I can launch it and 1 click and it is done let the Torque pull it out the back door..... don't have to worry about 1,2 2,3 flare and or crappy drums and broken parts in a c4.
You must speak of them redneck c4's.....lol
I have a steel billet fwd drum & a aluminum billet direct....I use PA's transbrake with NO FLARE! I use a higher low gear  set also....7+7 clutches...The little C4 is hangin in there....And so am i ... Very Happy
colormebad
Post  rmcomprandy March 17th 2014, 12:05 pm
Jaguar was at one time purchased by FoMoCo and they used a roller-ized Turbo Hydra-Matic 400.
A "low drag" 400 will hold-up to just about anything ... if you can "hook it up" with a 3 speed.
The same attachment as a Powerglide, too.
Post  colormebad March 17th 2014, 12:24 pm
rmcomprandy wrote:Jaguar was at one time purchased by FoMoCo and they used a roller-ized Turbo Hydra-Matic 400.
Never knew that...
colormebad
Post  DILLIGASDAVE March 18th 2014, 2:17 am
The TH400 can have it's problems too.
It can hande decent power numbers with the usual TH400 upgrades (such as upgrading the OEM sprag bearing to aftermarket). But they can often start having problems burning up clutches when you combine HP numbers over 1000HP+ with RPM's in the 8500 and above range. The first problem is as it runs into/past this higer RPM range the OEM TH400 front pump design starts to have a cavatation problem resulting in a line pressure drop that's enough to let the clutches start slipping a bunch. The other problem is it's hard on the clutches at these RPM's when the heavy OEM drums take time to spool-up to speed during the gear changes.
Replacing the OEM TH400 drums with aftermarket aluminum drums helps part of this situation a bunch by reducing roataing weight so everything spools-up to speed faster. The high RPM pump cavatation problem can be cured with a special TH400 anti-cavatation front pump from Steve Griner. Along with the front pump Griner also offers a TH400 trans brake with better line pressure numbers than what the other brand's off the shelf TH400 trans brakes have.
Post  supervel45 March 18th 2014, 3:14 am
You also get into input shaft diameter, with different transmissions. Yes I know they make hardened ones. They also make hardened ones for the larger diameters also. Don't see to many Buick GN's running in the 7's with a TH200, do you. You get to a certain HP level, and the smaller transmissions, just don't cut it very long. The C6 front pump bushing coment, was pretty close to the truth I am afraid. The C6's have come a long way, but the the TH400's are tough customers, and have more aftermarket support, just like the Glides. If your C4 is working good, more power to you. Put some more nitrous to if you have not allready, and let us know then. I would also not be to keen on a brazed drum. A frozen/heated pressed fit sleeve, won't fracture, if done correctly.
Post  colormebad March 18th 2014, 8:39 am
We have sprayed 400 on them all day long....On this new build im starting out with 175 on the first fogger and get the tune right, then adding the 275 second fogger...Then go from there....
colormebad
Post  richter69 March 18th 2014, 12:43 pm
I spray 350 on my sbf/c4 w no issues. The bbf car pissed it off though.
Post  supervel45 March 18th 2014, 12:59 pm
richter69 wrote:I spray 350 on my sbf/c4 w no issues. The bbf car pissed it off though.
Thats all I was getting at. You said the SBF was in the high 8's. If you turboed it or put more HP on the SB it might not like that either at a certain point.
Post  richter69 March 18th 2014, 1:09 pm
agreed, I dont see this car getting much faster anytime soon. If it does powerglide ftw lol
