5 disk forward drum
5 disk forward drum Empty 5 disk forward drum
Post  HorsinAround March 16th 2016, 10:56 am
The C6 trans I took apart has a 4 disk forward drum without the wave plate, so I have a 5 disk coming. Will the planetary from the 4 disk drum work in the 5 disk drum or is there something else I need to change?
http://www.frontpagefab.com
5 disk forward drum Empty Re: 5 disk forward drum
Post  Frank Merkl March 16th 2016, 11:29 am
the planetery is the same but you'll need a '76 and later ring gear and hub as the torrington pocket is deeper in the drum .330" vs .400"
Post  HorsinAround March 16th 2016, 11:35 am
I have a couple other C6's laying around. Is there a way to determine what year they are without opening them up?
Post  Frank Merkl March 16th 2016, 2:07 pm
look at the casting RF # on the drivers side of the case ,look for RH D7AP is the '76 and latter syle
