k member spacer?
k member spacer?
#1. I have a fox body mustang wanted to no is it ok to run a spacer to get the motor to clear k member/pan to get it in and will it mess with fron suspension was told it was ok 1 1/2 to 2 ?
#2 I have to car on stands and level it it best to have motor at 0 with the car or do you want a few degrees back like 3 1/2 to 4 ?
I have top bell bolt 2" below the last rib on the fire wall it it to low ?
I now have it a a 2" spacer and the motor at zero degrees and the car level
need to no be for I weld in mid plate and motor plate?
Any help would be appreciated Thanks
MustangDan- Posts : 140
Re: k member spacer?
Please help out if you can
Keep at it Dan. We're getting it done!
yellowhorse7- Posts : 1382
Yeah that's for all the help just a little header fitting to go everything else is done and look good
» BBF to C-6 spacer plate
» spacer and plates
» What spacer do u guys run with the mafi intake ,ANY?
» Carb spacers??
» Carb Spacers
» spacer and plates
» Carb spacers??
» Carb Spacers
