camshaft identification
camshaft identification Empty camshaft identification
Post  rcasonbbf March 1st 2014, 9:17 pm
Can lift b measured with micrometer or install in.mock block and do it that way? Thanks for any help.
rcasonbbf
camshaft identification Empty Re: camshaft identification
Post  supervel45 March 1st 2014, 10:31 pm
Yes it can.
camshaft identification Empty yes it can?
Post  rcasonbbf March 1st 2014, 10:37 pm
Micrometer method explain how please? Block method I can figure that out. Thanks
rcasonbbf
Post  supervel45 March 1st 2014, 10:48 pm
The cam would have to be out of the vechicle. If it is a dual pattern cam mark an intake and exhaust lobe. Measure the greatest distance on the lobe (top to bottom, and record. Then measure the smallest distance (side). Subtract the numbers, smallest from largest. Record the result and multipy by your rocker arm ratio, 1.73" is stock BBF. Subtract the amount of lash you run from the lift if it is a mechanical. This should get you pretty close to the lift at the valve.
camshaft identification Empty mic method
Post  rcasonbbf March 1st 2014, 10:57 pm
Sides of lobe or actual billet core?
rcasonbbf
Post  supervel45 March 1st 2014, 11:12 pm
Sides of lobe. The first calculation will give you lobe lift, and can be referenced in cam catalogs as such.
Post  powerstrokeace March 2nd 2014, 10:24 am
call your local machine shop and ask them if they have or know of some that has a cam doctor. they can give you all the info possible for a small fee
Ace
powerstrokeace
powerstrokeace
