need help wiring
need help wiring
with a transbrake.. Never wired or use a transbrake, so i need some help
pigs521bbf- Posts : 173
Re: need help wiring
One wire or two wire? What systems do you have on the car?
whatbumper- Posts : 3024
The value body is from frank m and the button is a b&m 2 wire. I have Mallory hyfire ignition box.
power one side of the buttom ,the other side goes to the transbrake wire and the 2 step activation wire
Frank Merkl- Posts : 1524
Like Frank said and the other wire on the solenoid on tranny ground it.I use my crossmember bolts to ground mine.
bigjohn2007- BBF CONTRIBUTOR
Solenoid is internal and grounded to the vb, one wire hook up
sorry my badFrank Merkl wrote:Solenoid is internal and grounded to the vb, one wire hook up
i hate to sound dumb but the one wire coming out of the transmission will go to the wire on the button and the other wire will go to 12v power source correct?
Ever have arcing issues within the transmission?Frank Merkl wrote:Solenoid is internal and grounded to the vb, one wire hook up
let's see , ground wire bolted to vb , vb bolted to case , case bolted to engine block, engine block grounded to - battery terminal , Arcing ?? don't really see a problem , now if it was grounded to the output shaft it would be a different story!
We've seen tons of steel arcing with glides and C4's from various companies when grounded in that manner. We've never had a C6 back in after we built them to see on those. I was asking about your particular valve bodies in this case in which I have never laid my hands on.
Thanks for the input.
» best wiring kit?
» WIRING QUESTIONS:
» Air Compressor wiring
» Wiring questions
» Starting and Wiring Help!
» WIRING QUESTIONS:
» Wiring questions
