Which 460 Heads require special pistons..
fordguy69
514F-1
Which 460 Heads require special pistons.. Empty Which 460 Heads require special pistons..
Post  514F-1 March 30th 2014, 7:59 pm
I know that A460 heads require special pistons, but do P51's, SCJ's, and Edelbrocks?? Just curious which required a special piston, and which used a standard piston similar to what a factory head would require...sorry for what may be a dumb question, but just trying to learn..
514F-1
514F-1
Which 460 Heads require special pistons.. Empty Re: Which 460 Heads require special pistons..
Post  fordguy69 March 30th 2014, 8:56 pm
SCJ's and P-51's definitely require unique pistons.
fordguy69
Post  schmitty March 30th 2014, 9:22 pm
Actually the SCJ's can be run with dished cast stock piston. Not sure if the P51's will do the same.  If you are going to a flat top or dome, then specific pistons for them are required.  The Eddies are standard valve layout.
Post  dfree383 March 30th 2014, 10:05 pm
The p-51s and ford racing Kaase SCJs use the same valve layout.
Post  514F-1 March 30th 2014, 10:10 pm
So, basically SCJ's, and P51 heads require the same pistons, and A460's require their own. And Factory, A429 and Edelbrocks are very similar and can use the same pistons..
514F-1
514F-1
Post  dfree383 March 30th 2014, 10:11 pm
Yep
Post  514F-1 March 30th 2014, 10:26 pm
dfree383 wrote:Yep
Cool, got it, thanks!
514F-1
514F-1
Post  rmcomprandy March 30th 2014, 10:59 pm
fordguy69 wrote:SCJ's and P-51's definitely require unique pistons.
That would really depend upon the size of the camshaft. The valves are far enough up in the head that a specific valve notch is not necessary for a lot of camshafts. Anything under about 238@.050" degrees duration usually does not present any contact problems..
Post  bbf-falcon March 31st 2014, 1:13 pm
514F-1 wrote:So, basically SCJ's, and P51 heads require the same pistons, and A460's require their own. And Factory, A429 and Edelbrocks,+bluethunder,and TFS streets are very similar and can use the same pistons..
