4150 Carbs
4150 Carbs
I have two Barry Grant 850 alcohol carbs. These have BG, bodies, blocks and bowls, glass sights for fuel level, brass floats, #40 squirters. These will need to be serviced prior to use. Repeat, these are not ready to bolt on and go. I haven't used them in years and are missing some bowl bolts and one has missing air bleeds. $200 each firm + shipping PayPal +3%
Carb #1
Carb #2
Carb #1
Carb #2
Curt- Posts : 2791
Re: 4150 Carbs
Curt do these carbs have aluminum main bodies or are they zinc? What size butterflys? Lastly were they set up for a tunnel ram as a pair or are they calibrated for single four barrel use? Thanks
bluef100fe- Posts : 379
Re: 4150 Carbs
I would assume they are cast aluminum. The primaries and secondary's are 1.68". They were originally sold as pair to run together, but have been ran as singles on different engines both small and big since then. One has 177 jets square and the other has 134 square.
Curt- Posts : 2791
» Special Holley Center Squirter carbs FOR SALE (TUNNEL RAM CARBS)
» BG Carbs...
» Parts selection for blown application (Budget - Mild Boost)
» CHeads Intake Split dominators
» SV 1 Carbs
» BG Carbs...
» SV 1 Carbs
