351w shaft mount rockers
+9
Dave C.
lghting94
KY JELLY
whitefield
DanH
kim
jason
13 posters
351w shaft mount rockers Empty 351w shaft mount rockers
Post  jason May 1st 2014, 8:36 pm
    does anyone know anything about these rockers and if they're a performance option ford had? I've never seen shaft rockers on a 351w. I'm trying to send a pic but it won't let me
Last edited by jason on May 1st 2014, 8:47 pm; edited 1 time in total (Reason for editing : Can't pull up pic)
jason
jason
351w shaft mount rockers Empty Re: 351w shaft mount rockers
Post  jason May 1st 2014, 9:14 pm
IMG_0216.jpeg. Don't know if this works
jason
jason
Post  kim May 1st 2014, 9:38 pm
has to be hosted on www somewhere. Not just your computer.
kim
Post  DanH May 2nd 2014, 2:55 am
jason wrote:    does anyone know anything about these rockers and if they're a performance option ford had? I've never seen shaft rockers on a 351w. I'm trying to send a pic but it won't let me
only shaft cption I'v seen for (non-oem)shaft system offered by Ford was for the C460 head
DanH
Post  bbf-falcon May 2nd 2014, 4:51 am
I'm not familiar w/small block race heads.Not sure if the Yates heads had shaft or not.
Post  whitefield May 2nd 2014, 6:58 am
Have any part numbers and are they on an Windsor head or cleveland valve style head ?
whitefield
whitefield
Post  maverick May 2nd 2014, 7:20 am
A friend has shaft rockers on a Yates headed 445" Windsor.  Not sure who made 'em but I'll find out if you like.
Post  KY JELLY May 2nd 2014, 7:25 am
C3 yates head T&d and jesel make rockers for them
KY JELLY
KY JELLY
Post  jason May 2nd 2014, 7:54 am
Ok I got it, they're on a Windsor and the engine is in a truck
https://s151.photobucket.com/user/ryggzstang/media/Mobile%20Uploads/2014-05/616C544D-F0B1-42A7-99B9-F893BDB48EEE.png.html
jason
jason
Post  lghting94 May 2nd 2014, 8:28 am
The engine in that link is not a 351w. It is an FE might be an old 352
lghting94
lghting94
Post  Dave C. May 2nd 2014, 8:40 am
yep
Dave C.
Post  jason May 2nd 2014, 12:11 pm
Thanks. It runs, is it worth anything?
jason
jason
Post  maverick May 2nd 2014, 2:00 pm
jason wrote:Thanks. It runs, is it worth anything?
That will depend on which FE engine you have.  Some rare versions of the FE are real pricey.  Even pieces of a 427 can be worth a pile. At the other end of the scale, the value may be directly related to its weight. Yours is most likely from an old Galaxie, a full size Merc or a truck. Worthwhile to try to find out, tho.
Post  res0rli9 May 2nd 2014, 2:59 pm
If in a truck mite also be a 360ci. witch is a destroked 390 and could also be a 390 they where in trucks to.
If its a big truck its a 361
Post  maverick May 2nd 2014, 3:25 pm
Lemme take a shot at this......332-352-360-(361FT)-390-(391FT)-406-410-427-428. Did I leave any out? Suspect
Post  whatbumper May 2nd 2014, 3:32 pm
maverick wrote:Lemme take a shot at this......332-352-360-(361FT)-390-(391FT)-406-410-427-428.  Did I leave any out? Suspect
There was also a 330.  Had one in a mercury car before.  It had a smaller bore and longer stroke than the 332.
Post  maverick May 2nd 2014, 4:42 pm
You're right. According to the Ford truck enthusiasts forum, it was also an FT...small bore, 352 stroke, low compression truck anchor. Live and learn.
Post  crittersf1 May 2nd 2014, 5:08 pm
Was also a truck 359.
crittersf1
crittersf1
Post  Lem Evans May 2nd 2014, 5:56 pm
Get some thing cool like a 538" truck engine Laughing
Post  jason May 2nd 2014, 8:09 pm
Wow lots of info! Thanks guys, I'm gonna try and get numbers off of it.
jason
jason
Post  DanH May 2nd 2014, 8:12 pm
Lem Evans wrote:Get some thing cool like a 538" truck engine Laughing
Plus some cool higher rate front springs
DanH
Post  jason May 2nd 2014, 8:52 pm
It's stamped 352 on the front of the block, it's got a 4 barrel and it's on a 65 truck frame and runs good. A friend is selling it, but don't know what to ask for it.
jason
jason
Post  maverick May 2nd 2014, 9:10 pm
You may find that "352" on other size engines, too...not necessarily a good indicator of what's inside.
Post  whatbumper May 2nd 2014, 10:26 pm
maverick wrote:You may find that "352" on other size engines, too...not necessarily a good indicator of what's inside.
Yep,  that was usually used just as an indicator that it was an FE series engine.  My 428 had that cast on it and it was a real 428 out of a wrecked Crying or Very sad numbers matching car.
Post  jason May 2nd 2014, 10:32 pm
Ok, I guess I'm gonna have to dig a little deeper. Is there anything externally that may narrow it down. We don't wanna open it up, it's a really good runner.
jason
jason
